# Deploy your IoT application in any language
> Build scalable and reliable IoT applications in any language using a PaaS API and architecture.
![Deploy your IoT application in any language](https://tago.io/og/blog/any-language.png)
IoT is already a global phenomenon, with devices and sensors in use all across the world. There are TagoIO users present in more than 100 countries. Releasing an IoT application in various languages helps to ensure that the maximum amount of people can use it, regardless of their location or native language, additionally allowing developers to tap into new markets and reach new customers.
Deconstructing language barriers can be a complex and time-consuming process, but it's worth the effort to make your IoT application as accessible as possible.
## How can TagoIO help you?
TagoIO can help you deploy a multi-language application by providing a platform that's able to adapt to any language. By using our Dictionaries & Multi-language feature, it's possible to create your own dictionary or import an external dictionary; you can even create your own custom language!
![Dictionaries & multi-language](./images/any-language/oxsfnJaO45LnI2mXDo36xKv2wI.png)
Besides the Dictionaries & Multi-language feature, users can also edit the text in some widgets by choosing the Custom Text option. Inside the Custom Text option, you can either enter a new text directly or substitute it by using your dictionary.
![How to set up multi language using TagoIO](./images/any-language/vphqci7V5X0Mhsns2rwGzZx5EN0.png)
These options make it easy for you to deploy your application in multiple languages.
## Want to know more?
For more information on how to use Dictionaries & Multi-language, visit its [documentation](https://help.tago.io/portal/en/kb/articles/489-using-dictionaries-multi-language) page. You can also learn more about TagoIO's cloud platform and how to use it effectively in our [IoT course](https://tago.io/academy/).
