# BrDot Selects TagoIO Platform to Empower New IoT Applications Based on Web3-Extended LoRaWAN Network
> Experience how TagoIO and BrDot work together in tackling the challenge of unreliable connectivity in the Brazilian countryside. With only 47% of Brazil's rural population having significant connectivity services, the integration aims to bridge the digital divide through the Helium network, providing decentralized IoT connectivity for smart farming. Explore the use cases, such as real-time grain monitoring and smart irrigation, enabled by IoT sensors and a low-cost, long-range LoRaWAN network. Discover BrDot's integrated approach, using Helium's decentralized network and private gateways to empower rural farmers with technology, ultimately boosting agricultural yields. Learn how to integrate BrDot's LoRaWAN with TagoIO for rapid deployment and customization of IoT solutions in the Brazilian countryside.
![BrDot Selects TagoIO Platform to Empower New IoT Applications Based on Web3-Extended LoRaWAN Network](https://tago.io/og/blog/brdot-selects-tagoio.png)
If you've ventured into the vast Brazilian countryside, you've likely encountered a significant challenge: unreliable connectivity. This issue becomes even more pressing in the context of smart farming. Many rural regions in Brazil remain untouched by the possibilities of LoRaWAN and IoT connectivity. TagoIO is thrilled to announce its new integration with [BrDot](https://www.brdot.com.br/) in response to this critical issue. Despite advancements, according to the Inter-American Institute for Cooperation on Agriculture, only 47% of Brazil's rural population has significant connectivity services.
## The Challenge of Rural Connectivity
Rural areas in Brazil face a unique challenge - a lack of dependable network connectivity. This issue is especially problematic for smart farming initiatives. There are still vast regions in Brazil where LoRaWAN and IoT connectivity concepts are unfamiliar. Some use cases that will be enabled by the use of IoT sensors and a low-cost & long-range network for smart agriculture include: real-time monitoring of grain in silos, smart irrigation systems that reduce water waste, local weather stations to provide high precision information of air and soil conditions, and more.
![](./images/brdot-selects-tagoio/aCOPugR5680gMpHzSH0yvvgAnP4.jpg)
Embrapa Dairy Cattle Research Facility, Coronel Pacheco, MG
![](./images/brdot-selects-tagoio/hXzpXAzvHHGwrQcjfeDu0ewOlYw.jpg)
Technical visit to aquaculture project, Tocantíns
## BrDot's Helium Network: Bringing Connectivity to Brazil
BrDot is pioneering the introduction of the [Helium](https://www.helium.com/) network in Brazil, a decentralized wireless network with over 6,000 access points that cater to IoT connectivity needs across Latin America. Check out the map below to see Brazil's growing number of Helium access points.
## A Thorough Approach
BrDot's approach is marked by decentralization and comprehensiveness. Their services encompass the public Helium network and private gateways (Gateway as a Service, GaaS) to extend IoT connectivity reach based on the LoRaWAN technology. The strategy for using the Helium network is highly scalable. BrDot can provide widespread coverage with a cross-sourcing approach without relying on a single provider. This opens up new possibilities for rural farmers, offering them access to IoT connectivity and enabling them to use technology to boost agricultural yields and reduce operational costs.
## How to Integrate BrDot's LoRaWAN with TagoIO
Between TagoIO and BrDot, the vision is clear: to bridge the digital divide in rural Brazil, enabling IoT technology to flourish and empower smart farming.
BrDot simplifies the device-to-cloud connectivity process with TagoIO. It offers access to a wide array of TagoIO advantages, including rapid deployment of IoT solutions from your computer to your clients' mobile devices, hundreds of pre-certified IoT devices ready to use, and an extensive range of customization and analytics options. [Delve deeper into the integration of your devices](https://help.tago.io/portal/en/community/topic/integrating-brdot-lorawan-with-tagoio) using the BrDot LoRaWAN network with TagoIO.
