# Build IoT Solutions Faster with Claude and TagoIO MCP
> TagoIO MCP connects Claude directly to your live IoT platform. Query device data, detect anomalies, and generate Analysis scripts, all in plain language.
![Build IoT Solutions Faster with Claude and TagoIO MCP](https://tago.io/og/blog/build-iot-solutions-faster-with-claude-and-tagoio-mcp.png)
IoT development is full of repetitive tasks. Querying device data, debugging pipelines, writing Analysis scripts, hunting for anomalies: each one takes time. TagoIO MCP changes the workflow. It connects AI assistants like Claude directly to your live TagoIO platform so you can do those tasks in plain language.
## What Is TagoIO MCP?
MCP stands for Model Context Protocol. It is an open standard that lets AI assistants talk directly to external tools and data sources. TagoIO MCP is a server built on that standard. It gives Claude, ChatGPT, Cursor, or any MCP-compatible AI assistant read and write access to your TagoIO environment.
That means your AI assistant is not working from guesswork or outdated training data. It is working from your actual devices, dashboards, and data pipelines, live.
## What You Can Do With It
Query device data in plain English. Instead of writing a query in TagoIO's query language, you ask: "Show me temperature readings from device X over the last 48 hours." The MCP server translates that into a platform call and returns the result.
Detect anomalies without writing code. Ask Claude: "Find temperature spikes that deviate more than 2 standard deviations from the mean across all devices in my fleet." The assistant runs the analysis against your live data and flags the outliers.
Find inactive devices instantly. "List all devices that haven't sent data in the last 24 hours." Useful for fleet health checks, especially across deployments with hundreds of sensors.
Generate Analysis scripts from a description. Tell Claude what the script should do, "Send an SMS alert when a tank level drops below 20%", and it writes the TagoIO Analysis script for you. You review it, deploy it, done.
Debug data pipelines faster. When data stops flowing, describe the problem to Claude. It can inspect your device configurations, check recent payload history, and suggest where the break is.
## Who Benefits Most
IoT application developers spend less time on boilerplate and more time on product logic. Writing Analysis scripts, setting up alert conditions, and querying historical data all get faster.
Platform administrators can audit fleet health, spot silent devices, and manage configurations through conversation instead of clicking through dashboards.
Data analysts who are not deeply familiar with TagoIO's data model can get answers from device data without learning the platform's full query syntax first.
## How to Install TagoIO MCP
The MCP server is open source and published on GitHub at https://github.com/tago-io/mcp-server
Installation takes a few minutes. You need a TagoIO account, an API token with the right permissions, and an MCP-compatible AI client. The full setup guide is in the official documentation:
https://docs.tago.io/docs/tagoio/tago-ai/tagoio-mcp-ai-powered-iot-data-integration
## What This Is Not
TagoIO MCP is not a magic button that replaces your engineering team. It does not make decisions for you, and it does not deploy anything without your review. It is a tool that removes friction from tasks you already know how to do.
## Next Steps
- Read the full setup guide: https://docs.tago.io/docs/tagoio/tago-ai/tagoio-mcp-ai-powered-iot-data-integration
- Get the MCP server source code: https://github.com/tago-io/mcp-server
- New to TagoIO? Start here: https://docs.tago.io/docs/tagoio/getting-started/
- Want the full developer walkthrough? Read [Claude + MCP + TagoIO for IoT Developers](/blog/claude-mcp-tagoio-for-iot-developers)
