# New Device Tabs configuration
> Take a look at our recent changes in the Device configuration tabs. Now you will find the Emulator inside each device and with some format examples ready to be used. Developers can emulate data in two formats: JSON or RAW payloads.
![New Device Tabs configuration](https://tago.io/og/blog/device-new-tabs.png)
Take a look at our recent changes in the Device configuration tabs. Now you will find the **Emulator** inside each device and with some format examples ready to be used. Developers can emulate data in two formats: JSON or RAW payloads.
The feature 'Token & Serial Number' management has been moved into the General Information tab.
And the 'Configuration Parameters' tab is now showing the status of the parameters downloaded onto the device more clearly: **Read** means that the device already got the parameter.
Also, when using the new **Live Inspector** to monitor data traffic, users can navigate in other tabs without resetting the historical data of the main display.
We hope you enjoy!
![Device configuration and emulator](./images/device-new-tabs/PLAIu8QiMs0oduKIx2AnNM0VZSU.png)
