# Connection Settings option removed
> We have removed the option 'Connection Settings' located in the tab 'More' of each device and decided that all data inputs will be counted as 1 transaction even considering that the data will be visualized in real-time with the Action verification activated.
![Connection Settings option removed](https://tago.io/og/blog/device-settings-removed.png)
Good news!
We have removed the option 'Connection Settings' located in the tab 'More' of each device **and** decided that all data inputs will be counted as **1 transaction** even considering that the data will be visualized in real-time with the Action verification activated.
Previously, developers had to count up to 3x transactions for each variable that was sent by the devices if the options to show data in real-time and Action verification were enable.
It means that the Data Input transactions in your account can decrease up to 3 times, starting on Aug,2nd. Take a look in your Profile and check the Data Input usage statistics.
TagoIO Team.
