# How System Integrators Build IoT Solutions with TagoIO
> System integrators who build custom IoT stacks for every client hit a growth ceiling. Here is how to build a repeatable delivery model on TagoIO.
![How System Integrators Build IoT Solutions with TagoIO](https://tago.io/og/blog/how-system-integrators-build-iot-solutions-with-tagoio.png)
Every client is different. Different hardware. Different connectivity. Different data requirements. If you are a system integrator, you already know this. And you know that building a custom IoT stack from scratch for each new client is not a business. It is a treadmill.
The integrators who scale do it by building a repeatable delivery model. One platform. Multiple client environments. Build once, apply everywhere.
## The Problem with One-Off Builds
When you build a custom IoT solution for each client, you are not just building the solution. You are also building the infrastructure underneath it: the device management layer, the data pipeline, the dashboard engine, the alerting system, the user management, and eventually the mobile app.
Each of those is a real engineering project. And when the client asks for a change, every custom layer has to be updated separately.
Integrators who work this way hit a ceiling. They can deliver two or three projects at a time before the support burden from previous clients starts limiting new work.
The alternative is a platform model. You configure, not code. You deploy a working solution in days, not months. And when a client asks for a change, you make it in one place.
## How TagoIO Is Structured for System Integrators
TagoIO's architecture is built for multi-client deployments. Each client gets a separate environment inside the platform: its own devices, its own dashboards, its own users, its own data. Clients cannot see each other's environments.
Key features that matter for SIs:
Multi-tenant architecture. Each client profile is isolated. Devices, dashboards, and data do not cross between profiles.
Blueprint dashboards. Build a dashboard template once. Apply it to each new client in minutes. When a building automation client needs the same monitoring layout as the previous one, you are not rebuilding. You are applying a blueprint.
Serverless Analysis scripts. TagoIO's Analysis environment runs JavaScript or Python without a server to manage. Write the logic once and deploy it across clients who share the same use case.
500+ device integrations. Connect whatever hardware the client already has. LoRaWAN sensors, MQTT devices, HTTP-connected controllers. TagoIO parses the data regardless of the manufacturer.
## TagoRUN: The Client-Facing Portal
TagoRUN is TagoIO's white-label portal feature. Clients access a portal at your domain (or a tago.run subdomain), with your logo and your colors. The TagoRUN mobile app is available on iOS and Android. Clients check their data without knowing what platform is running underneath.
Access control is fine-grained. You decide which dashboards each user sees and what data they can access.
Full TagoRUN documentation is at [https://docs.tago.io/docs/tagoio/tagorun/](https://docs.tago.io/docs/tagoio/tagorun/)
## A Real Onboarding Workflow
Here is what onboarding a new building automation client looks like in practice:
Step 1: Create a client profile. In your TagoIO account, create a new profile for the client.
Step 2: Add devices. Connect the building's sensors via LoRaWAN, MQTT, or HTTP. If you have connected this device type before, the parser is already built.
Step 3: Apply a blueprint dashboard. Use a template you built for a previous client. Adjust labels, thresholds, and overlays for this building. This takes minutes, not days.
Step 4: Set up the TagoRUN portal. Configure the client-facing portal with their company name, logo, and color scheme.
Step 5: Configure Actions and Analysis. Set up automated alerts for out-of-range readings. Deploy any Analysis scripts needed for this building.
The client is live. Your team moves to the next project.
## Why This Model Works
The value you deliver as a system integrator is your domain expertise. The platform infrastructure is not where you add value. It is where you spend time you should not have to spend.
TagoIO handles the infrastructure layer. You handle the solution layer. That is the model that scales.
## Next Steps
- Explore the SI partner program: [https://tago.io/partners](https://tago.io/partners)
- Browse real-world use cases: [https://tago.io/use-cases](https://tago.io/use-cases)
- Start building for free: [https://admin.tago.io](https://admin.tago.io)
