# Enhanced Security and Control features: Introducing Access Management for 'Analysis'
> TagoIO is thrilled to announce a significant update to its Analysis feature, the Access Management for Analysis. This update aims to enhance control and security by preventing unauthorized usage of resources. The blog emphasizes the importance of keeping the automatically added Access Management rule for Analysis to ensure the continued functioning of the system.
![Enhanced Security and Control features: Introducing Access Management for 'Analysis'](https://tago.io/og/blog/introducing-access-management-for-analysis.png)
We are thrilled to announce a significant update to our [TagoIO Analysis](https://help.tago.io/portal/en/kb/articles/29-analysis-overview) feature: the Access Management for Analysis. The AM for Analysis update has been designed to augment the level of control and security in your Analyses, preventing unauthorized usage of resources.
We will create an AM for Analysis rule in every TagoIO account to ensure their previous Analysis works normally. **This AM for Analysis rule must remain in place to ensure the continued functioning of the system**. Please exercise extreme caution when considering the deletion of this rule, and only proceed if you are confident that you have integrated your system with the appropriate AM rule.
## Why are we adding AM for Analysis?
In our previous system, every Analysis required a Profile Token for system integration. While effective, this setup could inadvertently expose the token, creating potential security vulnerabilities. Analyses also had automatic access to services such as SMS, email, and notifications, which could lead to unmonitored resource usage.
The implementation of AM for Analysis in our system is our solution to address these concerns. With AM for Analysis, you can set specific rules, defining what your Analysis can access and which services it can use.
## Taking Control with AM for Analysis
AM for Analysis puts the power back in your hands, offering a user-friendly panel on the TagoIO Admin page to set your own directives, as exemplified in the image below.
![](./images/introducing-access-management-for-analysis/qJ6yw9zb5Jg0M4WHR89XwDTl4cg.png)
## Uninterrupted transition with continued API functionality
While we're introducing AM for Analysis, it's important to highlight that all existing APIs will continue to operate without any disruption indefinitely. Even though these will be marked as 'deprecated,' there's no need for concern regarding their functionality. Your current processes will remain uninterrupted for a smooth transition to the new system.
## How does AM for Analysis work?
We have prepared a simple example to illustrate the usage of the new API with the enhanced AM for Analysis. As you can see in the following code, there is no longer a need for a token to access the device list, not an analysis token or any token. All you need to do is create an AM to provide access to the device list, and then you're all set to use it. This truly represents the enhanced control and security offered by AM for Analysis.
![](./images/introducing-access-management-for-analysis/yTwWFFAfjHxx2EQqYYaQMVGmLo.png)
## Automatic AM Rule for Common Services
As we transition to AM for Analysis, we understand how important it is that your existing Analysis workflows remain unaffected. Therefore, we are automatically adding an AM Rule to all accounts. There is no need for action during this transition. This rule will allow all Analyses to access common services such as SMS, email, PDF, and notifications, as they do today. The transition will proceed with no actions needed on your end. However, it is important to be mindful of this new AM Rule. If deleted, all Analyses will lose access to these common services. We strongly recommend keeping this rule intact to maintain uninterrupted access to these services for your Analyses.
We are confident that the AM for Analysis update, offering superior control and strengthened security, will set a new standard in managing your IoT applications. TagoIO remains dedicated to consistently innovating and providing solutions that meet and exceed your needs.
As always, if you have any questions or need further assistance, you can open a ticket or [visit our community](https://help.tago.io/portal/en/community/tagoio).
