# Using IoT for Predictive Maintenance in Manufacturing
> How companies use IoT for predictive maintenance in manufacturing: the sensors that matter, the data pipeline, starting on one asset, and the ROI.
![Using IoT for Predictive Maintenance in Manufacturing](https://tago.io/og/blog/iot-predictive-maintenance-in-manufacturing.png)
Every plant manager knows the two ways maintenance usually goes wrong. You wait for a machine to break and then scramble, or you replace parts on a fixed schedule whether they need it or not. The first costs you unplanned downtime. The second costs you parts and labor on equipment that was still fine. Predictive maintenance is the attempt to fix something only when the equipment tells you it is about to fail, and IoT is how the equipment tells you.
This is not magic and it is not cheap to do badly. Done right, it starts small, proves itself on one asset class, and grows from there. Here is how companies actually run it.
## Reactive, preventive, and predictive are three different bets
Reactive maintenance is run-to-failure. You fix the machine when it stops. It is the cheapest approach to set up and the most expensive when a critical asset goes down mid-shift and takes the line with it.
Preventive maintenance trades that risk for a schedule. Replace the bearing every six months, change the oil every so many hours, regardless of condition. It reduces surprise failures, but you pay for service the asset did not need yet, and you still get failures between intervals because wear does not follow a calendar.
Predictive maintenance watches the actual condition of the machine and acts on what it sees. A bearing that is starting to fail shows up in vibration data weeks before it seizes. A motor drawing more current than it should is telling you something is binding. You service the asset when the data says it needs service, not before and not after it has already failed. The trade is that predictive needs instrumentation, a data pipeline, and someone who trusts the alerts enough to act on them.
## The sensors that actually tell you something
You do not need to measure everything. A handful of signals carry most of the early warning for rotating and electrical equipment.
**Vibration.** The workhorse for motors, pumps, fans, gearboxes, and anything that spins. Bearing wear, imbalance, misalignment, and looseness all show up as changes in vibration signature long before they show up as a breakdown.
**Temperature.** Heat is a symptom of friction, electrical resistance, and overload. A bearing running hotter than its neighbors, a motor housing climbing over time, a gearbox warming up under normal load are all worth a look.
**Motor current.** The current a motor draws reflects what it is fighting against. Rising or erratic current signatures point at mechanical load problems, electrical faults, and developing inefficiency without putting a sensor inside the machine.
**Acoustic.** Ultrasonic and audible monitoring catches things the others miss, like compressed air leaks, early-stage bearing defects, and electrical arcing. It is useful where you cannot get a contact sensor onto the asset.
Pick the signals that match your failure modes. A plant full of pumps and motors leans on vibration and current. A facility with a lot of compressed air leans on acoustic. Measuring a signal that has nothing to do with how your equipment fails just adds cost.
## The pipeline from sensor to action
A sensor reading sitting in a database has saved no one. The value comes from the path the data takes after it is collected.
It starts at the asset, where the sensor produces a reading. That reading moves over connectivity, whether cellular, LoRaWAN, wired, or a local gateway, into a platform that ingests and stores it. On the platform, the data meets logic. In the early days that logic is a threshold, a high-vibration alarm, a temperature ceiling, a current limit. As you collect history, the logic can grow into a model that learns the normal signature of each asset and flags deviation, which catches problems a fixed threshold would miss.
When the logic trips, it raises an alert. The alert reaches a human or a system that can act, and the action gets recorded. That last step is where most deployments quietly fail. The data was fine, the alert fired, and nothing happened because responding to it was not anyone's job. The savings live in the work order, not in the dashboard.
## Start on one asset class, not the whole plant
The instinct is to instrument everything at once. Resist it. A plant-wide rollout multiplies cost, integration effort, and the number of alerts before you have learned to trust any of them, and a flood of alerts nobody trusts is worse than no alerts at all.
Pick one asset class where failure hurts and the failure mode is well understood. Critical pumps, the main motors, a specific line of gearboxes. Instrument that class, get the alerts to a point where the maintenance team believes them, and prove the savings on something you can measure. Once the team trusts the system and you can point at downtime you avoided, expanding to the next asset class is an easy argument to make. Trying to boil the whole plant on day one is how pilots stall.
## What actually drives the ROI
The return on predictive maintenance comes from a few concrete places, and you should be able to point at each one.
Downtime avoided is usually the biggest. If a critical asset failing unplanned costs a known amount per hour in lost production, catching that failure before it happens is money you can defend. Longer asset life matters too, because servicing on condition instead of running to failure keeps equipment healthier for longer and stretches the capital. Fewer emergency call-outs show up in the maintenance budget directly, since planned work during a shift is cheaper than an after-hours scramble for a part you did not have on the shelf.
Be honest about the baseline. The ROI is the difference between what failures used to cost you and what they cost you now, and a remembered baseline flatters every project. If you do not know your current downtime cost, that is the first number to nail down, before you buy a single sensor.
## Dashboards people read and alerts people trust
Two things make or break adoption on the floor. The first is a dashboard that shows asset health at a glance, so the team can see which machines are trending the wrong way without reading raw numbers. The second is alerts the team trusts.
Trust is fragile. An alert that fires on noise, or fires ten times for one event, teaches people to ignore it, and an ignored alert is the same as no alert. Tune thresholds to the asset, suppress duplicate alarms, and route each alert to the person who owns the response. An alert that lands in the right inbox with enough context to act on is worth more than a dashboard full of charts nobody opens.
## Where TagoIO fits
TagoIO is the platform layer in that pipeline. It ingests the sensor data off your connectivity, stores it, runs the logic that decides what is normal, visualizes asset health on dashboards, and raises the alerts when something drifts.
A few things that matter for a maintenance deployment. The logic can start as a simple threshold and grow into a condition model as you collect history, without changing the rest of the stack. Alerts route to email, SMS, or to another system, so they reach whoever owns the response. And TagoIO integrates to a CMMS or ERP through its APIs, so a tripped alert can open a work order automatically instead of waiting on someone to transcribe it. For regulated environments, the platform is ISO 27001 certified and GDPR-aligned. If you resell to clients, TagoRUN offers a white-label version, and TagoCore is an open-source edge runtime for processing closer to the asset.
The platform handles ingest, storage, logic, dashboards, and alerts. The savings still come from your own operations and from someone acting on what the data shows. Start on one asset class, prove the number, and grow from there.
## Resources
- [See deployments and the problems they solve](https://tago.io/use-cases)
- [How the platform layer is priced](https://tago.io/pricing)
- [Browse device and sensor integrations](https://tago.io/devices)
- [Start building your own deployment](https://admin.tago.io)
