# LoRaWAN Coverage Testing: How Radio Mapping Tools May Prevent Failed IoT Deployments
> What radio mapping is, why you should test LoRaWAN coverage before installing sensors, and how to run a site survey with the Adeunis Field Test Device, with results decoded and mapped on TagoIO.
![LoRaWAN Coverage Testing: How Radio Mapping Tools May Prevent Failed IoT Deployments](https://tago.io/og/blog/lorawan-coverage-testing.jpg)
A LoRaWAN deployment rarely fails because of the sensors. It fails because a boiler room two floors down never had signal, and nobody found out until fifty devices were already on the wall. The fix at that point is a second site visit, a moved gateway, and a conversation with a customer who expected the project to be done. The return trip also costs money: travel time, site access authorization, and a technician pulled off other work. The total often reaches thousands of dollars, before any late penalties on projects funded by public bodies.
The step that prevents this is radio mapping: measuring real network coverage on site before and during deployment. Across the hundreds of customers running LoRaWAN gateways on TagoIO, the pattern is consistent. Teams that measure first install once. Teams that estimate from a floor plan go back.
This article covers when a coverage study is worth the effort, what a LoRaWAN network tester actually measures, and how to run one with the [Adeunis Field Test Device (FTD)](https://www.adeunis.com/en/field-test-device-iot/), a handheld tester that has a ready-made [connector on TagoIO](https://tago.io/devices/lorawan-loriot/adeunis-lorawan-field-test), so every measurement you take in the field lands decoded on a dashboard.
## Do you always need radio mapping?
No. The honest answer is that site size and construction decide.
On a small, open site, a single floor with line of sight and the gateway nearby, an experienced installer's judgment plus a spot check at the farthest sensor is usually enough. LoRa's link budget has plenty of margin for a warehouse bay or a one-story shop, and a formal survey would add little.
The calculation flips on large or complex indoor sites: multiple floors, basements, concrete and metal construction, boiler and technical rooms, or anything where the gateway count and position are still open questions. There, intuition fails in exactly the places the sensors are headed, and a point-by-point survey before installation is the cheaper path. A useful rule: if you cannot say with confidence how many gateways the site needs and where they go, measure before you buy.
The rest of this article is about the second case.
![Decision chart comparing a small, open site, where a quick spot check is enough, with a large or complex indoor site, where you should measure point by point before installing](https://tago.io/images/blog/lorawan-coverage-testing/when-to-radio-map.svg)
## What is radio mapping in LoRaWAN?
Radio mapping, also called a coverage study or site survey, is the practice of measuring LoRaWAN network quality at the exact locations where sensors will be installed, using a dedicated field tester instead of theoretical propagation models.
A coverage prediction tells you what the signal should be. Radio mapping tells you what it is, with the real walls, metal shelving, machinery, and neighboring RF traffic of your site included. The output is a set of geolocated measurements: signal strength, signal-to-noise ratio, and packet loss at each point, which becomes the evidence for where gateways and sensors go and whether the planned sensor positions will communicate.
Radio mapping answers two different questions depending on when you run it:
- **Before the project (network qualification):** Is there usable coverage here at all? If the site uses an operated network, does that network reach the basement? If it is a private network, how many gateways does the site need and where?
- **During deployment (validation):** Does this exact sensor position, on this wall, behind this cabinet, communicate reliably? Should the gateway move three meters before everything gets mounted?
## Why test LoRaWAN coverage before deployment?
Because the places where IoT sensors deliver the most value are the places where radio behaves the worst. Water meters sit in basements. Temperature sensors go into boiler rooms and cold storage. Machine monitors live between metal enclosures. Concrete, metal, and distance all attenuate the signal, and a site that looks small on paper can hide dead zones a floor plan will never reveal.
Skipping the survey does not remove the cost of these dead zones. It moves the cost to after installation, where it is larger:
- **Return visits.** A technician who installs a sensor that never joins the network comes back. On a multi-site rollout, repeated truck rolls can consume the margin of the entire project.
- **Misdiagnosed hardware.** Devices in weak coverage drain batteries faster and drop uplinks intermittently. Teams replace healthy sensors because nobody measured the radio link they were on.
- **Oversized or undersized infrastructure.** Without measurements, integrators either buy gateways they do not need or discover during commissioning that one gateway was never enough.
Adeunis describes a survey of roughly 100 measurement points across several square kilometers, including underground meters, which concluded that three gateways were needed for full coverage. The same method on a 1,000 m² office confirmed that a single well-placed gateway was enough. Both outcomes are wins: the point of the study is to replace the guess with a number before the purchase order, not after.
A field case from an Adeunis coverage study of two office towers in Barcelona makes the point sharper. Both buildings were planned for the same semi-private LoRaWAN network, 63 transmitters in total. In the first tower (7 office floors plus 3 basements), the initial hypothesis of a ground-floor gateway failed the field test, and measurements showed one gateway could reach the basements and ground floor but nothing above the 3rd floor; the validated architecture ended at three gateways, placed layer by layer. In the second, structurally similar tower, a single gateway in a 1st-basement elevator vestibule covered everything the project needed, and the measurements proved it. Same owner, same network, neighboring buildings, and the right answer was three gateways in one and one in the other. No rule of thumb gets you there; measuring does.
## What does a LoRaWAN network tester measure?
A field tester is a LoRaWAN end device that exchanges frames with the network and reports the quality of the link in both directions. The metrics that matter:
- **RSSI (Received Signal Strength Indicator):** the power of the received signal, in dBm. Values closer to 0 are stronger; a reading near -120 dBm is at the edge of what LoRa can demodulate.
- **SNR (Signal-to-Noise Ratio):** how far the signal sits above the local noise floor, in dB. LoRa decodes frames below the noise floor, down to about -20 dB at SF12, which is why SNR matters as much as raw signal strength in noisy industrial environments.
- **PER (Packet Error Rate):** the share of frames lost. A point with acceptable RSSI but high PER signals an unstable link, which is why a survey takes several exchanges per point rather than a single reading.
- **Spreading factor (SF):** which data rate the link needs. A link that only works at SF12 consumes more airtime and battery than one that holds SF7; mapping SF across the site predicts the battery life of the fleet you are about to install.
- **Downlink quality:** uplink and downlink are not symmetric. A tester that checks both confirms the sensors will also receive configuration and ACK frames, not only transmit.
A single green bar on a gateway's admin page tells you none of this. Point-by-point measurements at the future sensor positions do.
The combination of RSSI and SNR is what separates "connected" from "reliable". Two positions can both communicate today: one at -95 dBm RSSI and +5 dB SNR with a comfortable link margin, one at -118 dBm and -10 dB with almost none. The second link works until a pallet rack, a parked truck, or a humid summer takes away the few dB it had left. A survey records the margin, not only the connection.
## How do you run a LoRaWAN site survey with the Adeunis FTD?
![Adeunis Field Test Device, a handheld black LoRaWAN tester with an antenna, backlit screen and a round push button](https://tago.io/images/blog/lorawan-coverage-testing/adeunis-ftd-device.webp)
The [Adeunis FTD](https://www.adeunis.com/en/produit/ftd-network-tester/) is a handheld, battery-powered LoRaWAN Class A device built for exactly this job. It joins the network like any production sensor (OTAA or ABP), transmits on demand via a push button or periodically, and shows link results immediately on its backlit screen: uplink and downlink counters, RSSI, SNR, and the active spreading factor. With GPS enabled, each measurement is tagged with position and time, and the device stores the last 100 measurements for download. A built-in antenna mode emulates a device with a PCB antenna, so the readings reflect what a real compact sensor will experience rather than what an external antenna flatters. Regional variants cover EU863-870, US902-928 and AS923-1.
The survey procedure, condensed from Adeunis' [radio mapping methodology](https://www.adeunis.com/en/iot-radio-mapping-lorawan-coverage-testing/):
- **Plan the points.** Mark every future sensor location on the floor plan, and add the hostile spots on purpose: basements, boiler rooms, elevator shafts, metal-dense storage. For a private network, also mark the theoretical gateway position.
- **Activate the network.** On a private network, power the gateway at its planned position (a temporary mount is fine). On an operated network, go straight to measuring.
- **Measure each point.** Trigger several exchanges per point with the FTD and record RSSI, SNR, and PER in both directions. Multiple frames per point separate a stable link from a lucky one.
- **Adjust and re-measure.** If points fail, move the gateway, add a gateway or repeater, or relocate the sensor position, then measure again. Three meters of gateway placement can change the outcome of an entire floor.
- **Report.** Keep the measurement set as the coverage record for the site. It defines the architecture, and it is the baseline you compare against when something degrades a year later.
![Adeunis FTD held in front of an office building during a field test, its screen showing uplink and downlink results at SF7](https://tago.io/images/blog/lorawan-coverage-testing/adeunis-ftd-field.webp)
## How does the Adeunis FTD work with TagoIO?
The FTD is itself a LoRaWAN device, so every test frame it sends travels through your gateway and network server like production traffic. TagoIO keeps a public **Adeunis LoRaWAN Field Test** connector in its catalog, which decodes those frames automatically: uplink and downlink frame counters, the downlink RSSI and SNR the tester measured, GPS position, battery level, and the device's temperature arrive as named variables, with no parser code to write. Network integrations such as The Things Stack and ChirpStack add the gateway's uplink RSSI and SNR to the same device.
That turns the survey from a clipboard exercise into a live dashboard:
![Diagram of the data path: the Adeunis FTD sends a LoRaWAN uplink to a gateway, then to the network server, which forwards it to the TagoIO Field Test connector and a live survey dashboard](https://tago.io/images/blog/lorawan-coverage-testing/ftd-to-tagoio-data-path.svg)
- **A map of the survey as it happens.** With GPS enabled, each press of the button drops a decoded, geolocated point onto a TagoIO map widget. The person walking the site and the engineer back at the office look at the same data in real time.
- **A permanent coverage record.** The measurements persist as time-series data on the platform, next to the production devices they were taken for. When a customer reports a flaky sensor months later, the original survey values for that exact spot are one query away.
- **Shareable results.** The same dashboard becomes the coverage report you hand to the customer, through a shared dashboard or a [TagoRUN](https://tago.io/run) portal, instead of a PDF assembled by hand.
- **The same path as production.** Validating the FTD's uplinks through your network integration also validates the full chain: gateway, network server, and platform. When the survey works end to end, the production fleet inherits a proven route.
Setup is the standard connector flow: register the FTD on your LoRaWAN network server, point the integration at TagoIO, create the device with the Adeunis LoRaWAN Field Test connector, and press the button. The steps are documented in [Adding Devices with Connectors](https://docs.tago.io/docs/tagoio/devices/adding-devices-with-connectors).
## When should you repeat a coverage test?
Coverage is not a one-time property of a building. Re-run the measurements when:
- **The site changes.** New walls, new racking in a warehouse, new machinery, or a tenant fit-out can degrade links that were solid at commissioning.
- **The fleet grows.** Extending a deployment into a new wing or floor deserves the same measurements the original area received.
- **Devices misbehave.** Before replacing hardware that drops uplinks, measure the link at its position. A ten-minute test with the FTD regularly saves a sensor from being swapped for a radio problem it did not cause.
Keeping the tester in the commissioning kit, already registered on TagoIO, makes each of these a routine check instead of a project.
## Getting started
The Field Test Device and its documentation are available from [Adeunis](https://www.adeunis.com/en/produit/ftd-network-tester/); the FTD user guide for US 902-928 MHz covers the North American variant. On TagoIO, create a device with the Adeunis LoRaWAN Field Test connector and build a map and table widget for the decoded measurements, and the next site you survey writes its own coverage report.
If you are planning a larger rollout and want to see the full path from field measurement to customer-facing coverage dashboard, [request a demo](https://tago.io/request-demo) and bring your floor plan.
