# New method to rearrange widgets
> We will be releasing the new method to rearrange widgets on the dashboards later this week!Developers will be able to drag and drop the widgets in any open space, incuding keep them in the bottom of the dashboard. The 'magnetic' feature that was used to pull the widgets to the top will no longer be enable.
![New method to rearrange widgets](https://tago.io/og/blog/new-rearrange-method.png)
This new method will also fix a bug, that rarely happened, but was causing problems to users that had a high number os widgets mounted on a dashboard. It was messing with the order of the widgets whem users tried to reorganize one widget in the middle.
By combining this new method with a new feature that allows to add image on the dashboard background will create more visual possibilities.
**Notice:** You will need to create a open space before moving a widget to the desired location.
Let us know your experience with the new method.
TagoIO Team.
