# Real IoT Cold Chain Monitoring: A Field Walkthrough
> What a working IoT cold chain monitoring deployment looks like end to end: sensors, connectivity, thresholds, alerting, audit trail, and the dashboard the operator actually uses.
![Real IoT Cold Chain Monitoring: A Field Walkthrough](https://tago.io/og/blog/real-iot-cold-chain-monitoring-a-field-walkthrough.png)
Cold chain failures are expensive in a particular way: they are invisible until the product is already ruined. A freezer drifts two degrees overnight, nobody sees it, and a pallet of vaccines or seafood is scrap by morning. The loss is the easy part to measure. The lost trust with the customer is worse.
Temperature sensors are cheap now, so teams assume monitoring is solved. The problem is that a box of sensors is not a monitoring system. Readings nobody watches, alerts nobody receives, and a history nobody can pull for an audit do not prevent a single loss. What prevents losses is the system around the sensors. Here is what that system looks like end to end.
![A full-stack IoT platform for logistics and cold chain monitoring](https://tago.io/images/sectors/logistics/why-tagoio.webp)
## The sensors and where they go
Start with the measurement. Cold chain monitoring usually means temperature, and often humidity and door state. Place sensors where the product is, not where it is convenient: the back of the trailer, the middle of the pallet, the warm corner of the cold room. One sensor by the door tells you about the door, not the product.
Battery-powered LoRaWAN sensors fit this well. They run for years, reach across a facility, and survive the cold better than most wireless options.
## Connectivity that survives the environment
A freezer is a metal box, which is hard on wireless signals. LoRaWAN handles it better than short-range options, but you still verify coverage from inside the cold space before you trust it. For vehicles and transport, a cellular or hybrid link carries data while the asset moves.
Test from the worst spot, loaded, with the doors shut. Coverage that works in an empty warm room and fails in a full freezer is the failure you are trying to prevent.
## Thresholds and alerting that reach a person
This is where most deployments fall short. A reading is not an alert. You define the safe range, the time a breach is allowed to last before it matters, and who gets told, on which channel, at what hour. A two-degree spike for thirty seconds when a door opens is normal. The same spike held for an hour at 3am is a loss in progress.
The alert has to reach someone who can act, fast, by the channel they actually watch. An email nobody reads until morning is not monitoring.
## The audit trail
Cold chain is often a compliance problem as much as an operational one. You need a tamper-evident history showing that the product stayed in range, ready to export when a regulator, an insurer, or a customer asks. That record turns "trust us" into proof, and it is what protects you when something does go wrong.
## The dashboard the operator actually uses
The screen the team lives on is simple: current status per location, anything out of range right now, and recent history. Not a wall of charts. An operator should understand the state of the cold chain in five seconds and drill in only when something is wrong.
## What the deployments teach
The teams that get this right share a pattern. They place sensors where the product is, they tune alerts so the real ones are not buried under noise, and they treat the audit trail as a feature, not an afterthought. The hardware is the cheap part. The system around it is what saves the pallet.
TagoIO covers the system layer: ingesting sensor data over LoRaWAN or cellular, holding the history, running threshold and duration logic, sending alerts to the right person, and showing the status view the operator needs. The customer is the one who prevents the loss; the platform is what makes that possible.
See a cold chain setup on the [free plan](https://tago.io/pricing), or [book a demo](https://tago.io/request-demo) to walk through your facility and routes.
