# What a Real IoT Deployment Looks Like From Pilot to Production
> What a real IoT deployment looks like from proof of concept to steady-state operations, the phases, the durations, and where projects stall.
![What a Real IoT Deployment Looks Like From Pilot to Production](https://tago.io/og/blog/real-iot-deployment-from-pilot-to-production.png)
Most IoT deployments do not fail in the field. They fail in the gap between a demo that worked and a system someone can run for years. The technical part, getting a device to send data to a dashboard, is the part almost everyone gets through. What comes after is where projects stall, and it is rarely what the original plan accounted for.
A real deployment moves through phases. Each one answers a different question, and skipping any of them tends to show up later as a problem nobody can explain. Here is what the path actually looks like, what changes along the way, and where deployments get stuck.
## The phases, and what each one is for
**Proof of concept.** One device, or a handful, on a desk or a bench. The point is to prove the data path works: the device reports, the payload parses, a dashboard shows something real. This is fast, often a couple of weeks, and it should be. If a proof of concept drags on, the problem is usually unclear goals rather than hard engineering.
**Pilot with real devices in the field.** Now the devices leave the bench. They go on the actual asset, in the actual location, with the actual connectivity. This is where you learn what the proof of concept could not tell you: that the signal drops behind a metal door, that the battery drains faster in the cold, that the payload format changes when the firmware updates. A pilot runs in weeks, not days, because you need enough field time to see the failures that only happen occasionally.
**Limited production.** A subset of the full fleet, running the way production will run, but small enough to fix without a crisis. Alerts are live. Someone is watching them. This phase exists to test the operations, not the technology. If something breaks at fifty devices, you want to know before it breaks at five thousand.
**Full rollout.** The rest of the fleet comes online, often site by site or region by region rather than all at once. This takes months for any deployment of real size, because provisioning, installation, and verification all happen at human speed across many locations.
**Steady-state operations.** The deployment is no longer a project. It is a system that runs. Devices fail and get replaced. Firmware updates ship. Alerts fire and people respond. This phase has no end date, and it is the phase the original budget almost always underestimates.
## What actually changes between pilot and production
The pilot proved the idea. Production is a different job, and the difference is not just more devices.
**Scale changes the math.** A process that works when you provision ten devices by hand falls apart at a thousand. You need a way to register, configure, and group devices that does not involve a spreadsheet and a person typing.
**Device management becomes its own discipline.** In a pilot you know every device by name. In production you have devices you have never physically seen, in locations you will never visit, and you need to know which ones are healthy, which went quiet, and which are about to fail.
**Alerting has to earn trust.** A pilot alert that misfires is a minor annoyance. A production alert that cries wolf gets ignored, and an ignored alerting system is worse than none, because people stop looking. Getting thresholds right, suppressing noise, and routing alerts to the person who can act takes real tuning, and it happens after the pilot, not during it.
**Support and on-call appear.** When a device goes down at 2am and it matters, someone has to answer. Production means a support path and an on-call rotation, even a light one. This is a cost and a responsibility that pilots never have.
**Multi-site rollout introduces variation.** Different sites have different connectivity, different layouts, different people installing the hardware. What worked at the pilot site does not automatically work at the next ten.
**Firmware updates become routine and risky.** A field of deployed devices needs updates for security and features. Pushing firmware to thousands of devices without bricking any of them is a process you have to build and trust, and it is not something a pilot ever exercises.
## Where deployments stall
The phases are not the hard part. The transitions are. A few failure patterns show up again and again.
**Pilot purgatory.** The pilot works. Everyone agrees it works. And then nothing happens for months. Usually this is because the pilot proved the technology but no one built the business case for scaling, or no one was assigned to drive the rollout, or the budget for production was never real. The pilot becomes a permanent demo that proves a point nobody acts on.
**Data nobody acts on.** The dashboards are live, the data is flowing, and operations run exactly as they did before. The deployment generates information that changes no decisions. This is the quietest failure, because everything looks like it is working. The value of IoT lives in the action the data triggers, and if no action was ever wired up, the data is just expensive telemetry.
**No operations owner.** The project team builds the deployment and then moves on. Nobody inherits it. Devices start failing, alerts go unanswered, firmware goes stale, and the system degrades until it is unreliable, at which point people conclude IoT does not work. The real problem was that the deployment had a builder but no owner.
## The handoff to operations
The moment that decides whether a deployment survives is the handoff from the team that built it to the team that runs it. This handoff fails when it is treated as an afterthought.
A handoff that works includes the things operations actually needs: documented alert meanings and response steps, a way to see device health at a glance, a process for replacing dead hardware, and a clear owner who is measured on whether the system runs. The operations team does not need to understand how every parser works. They need to know what each alert means, what to do about it, and who to call when something is outside the runbook.
The deployments that reach steady state are the ones where operations was involved before the handoff, not handed a system they have never seen and asked to keep it alive.
## How a managed application layer shortens the path
A lot of the distance between pilot and production is work that has nothing to do with your specific use case. Provisioning devices at scale, storing and serving data, building dashboards, tuning alerts, managing firmware, watching device health. Every deployment needs these, and building them from scratch is where the months go.
This is the work a managed application layer absorbs. TagoIO sits on top of your connectivity and handles the parts that look the same across deployments: ingesting device data, storing it, running the logic, serving dashboards, and firing alerts. Device provisioning and grouping are configuration rather than custom code, which is what makes the jump from ten devices to ten thousand a setting rather than a rebuild. Because the platform is multi-tenant, a rollout across sites or clients does not mean standing up new infrastructure for each one.
For deployments where someone else will run the front end, TagoRUN gives system integrators a white-label layer to resell under their own brand, so the operations handoff can go to a partner rather than an internal team. At the edge, TagoCore is an open-source runtime for the device side of the same stack. And for regulated work, TagoIO is ISO 27001 certified and GDPR-aligned, which matters once a deployment holds real production data.
None of this removes the work of running a deployment. People still respond to alerts, replace devices, and own the system. What it removes is the months spent rebuilding the parts that every deployment shares, so the time you spend goes to the part that is actually yours.
## Resources
- [See deployments and the problems they solve](https://tago.io/use-cases)
- [Device management and provisioning at scale](https://docs.tago.io/docs/tagoio/devices/data-management/device-data-management)
- [Resell under your own brand with TagoRUN](https://tago.io/run)
- [Start building and test your own deployment](https://admin.tago.io)
