# Recurring Revenue for Food Processing Equipment Makers
> How pasteurizer, oven and filling line makers turn the records HACCP already requires into service plans, earlier CIP cycles, and output billed per liter.
![Recurring Revenue for Food Processing Equipment Makers](https://tago.io/og/blog/remote-monitoring-food-processing.png)
Remote monitoring lets a maker of pasteurizers, ovens, fryers, mixers or filling lines capture the records food regulation already demands, and sell that same data three times: as compliance evidence on demand, as a service plan that moves a cleaning cycle up before product is lost, and as output billed per liter or per batch. In the example on the [Food Processing solutions page](https://tago.io/food-processing), a dairy's pasteurizer holds the legal line through a fouling episode and closes the month with 3,000,000 liters pasteurized and a $4,500.00 invoice at $1.50 per 1,000 liters.
**Key points**
- The regulated signals and the commercial signals are the same signals: holding temperature proves compliance and detects fouling; fill weight proves the pack and detects giveaway.
- One batch record serves three buyers: the auditor, the service team, and the invoice.
- The whole catalog connects over what each plant has: ovens and fryers over Modbus, mixers over LoRaWAN retrofit sensors, pasteurizers over cellular or plant MQTT, remote lines over satellite.
- Washdown environments need industrial-grade instrumentation. NOVUS builds the transmitters and loggers this category calls for, and runs its own OEM business on TagoIO.
## One record, three buyers
![One batch record serves three buyers: the HACCP auditor, the service team acting on fouling before the batch, and the invoice billed per liter or per batch](https://tago.io/images/blog/remote-monitoring-food-processing/food-processing-batch-record.svg)
Most plants still satisfy HACCP with chart recorders and binders, which makes the most regulated machines in industry the least useful as data sources. The maker who ships the records digitally removes an audit headache on day one, and everything else in this article rides on that same stream at no extra instrumentation cost.
## The walkthrough: fouling caught before the batch
The page's simulated case runs through a dairy. Pasteurizer 4 holds milk at 73.1 degrees against a legal minimum of 72 degrees for 15 seconds; its heating water normally runs at a clean-plate reference of 76 degrees. One week, at the same flow, the heating water runs 2 degrees over clean and crosses the CIP limit: plates are fouling faster than the schedule assumed. The platform moves the clean-in-place cycle up to that morning and tells the plant. Plates come back clean, heating water returns to normal, and the batch never approaches the legal line. The month closes at 3,000,000 liters pasteurized, the legal minimum held throughout, and the $4,500.00 invoice issued.
The fleet view shows the commercial shape: 912,000 liters billed at $1.50 per 1,000 liters so far in the month ($1,368, up 5% on October), one pasteurizer of four needing attention, and $4,827 ready to bill across all four dairies, each line itemized in liters. The small cards show the same mechanics elsewhere on the line: a filling valve averaging 494 ml, 6 ml under its 500 ml nominal ($120 a month), and a screw drive watched at 41 A before a knife change ($36 a month).
## Which measurements carry the business?
| Measurement | Compliance role | Commercial role |
| Holding temperature | The legal record, per second | Fouling detection, uptime guarantee |
| Heating water temperature | Process evidence | CIP timed by condition, energy savings |
| CIP conductivity | Proof the clean happened | Chemical dosing service |
| Fill weight | Label compliance | Giveaway reduction, billing per pack |
| Oven and fryer temperatures | Food safety | Element and oil service by trend |
| Liters or batches produced | Traceability | The invoice itself |
## Hardware that survives the washdown
Food plants punish electronics, so the sensing layer matters more here than in any other machine category. NOVUS builds the industrial temperature transmitters, controllers and data loggers this environment calls for, and its own story shows the model from the inside: [NOVUS turned its measurement hardware into complete IoT solutions on TagoIO](https://tago.io/use-cases/how-novus-delivered-a-complete-versatile-iot-platform-for-oems), from silo alerts over MQTT to more than 200 automated monitoring points across waste-combustion processes. Pair that instrumentation with the machine PLC's existing Modbus data and the batch records assemble themselves; a payload parser absorbs proprietary controller formats as messages arrive.
## The business models, priced
| Model | What the plant pays for | Basis |
| Records subscription | HACCP evidence on demand, recall scope in minutes | $ per machine, monthly |
| Service plan | CIP by condition, batches never diverted | $ per machine, monthly |
| Output billing | Product actually made | $ per 1,000 liters or per batch |
| Line guarantees | Uptime through production windows | Premium on the output rate |
The move down this table is the ladder from [Climbing the Fusion Ladder](https://tago.io/blog/climbing-the-fusion-ladder), with one advantage unique to food: the first row is not optional for your customer, so the infrastructure that powers every other row is funded by regulation.
## Where does TagoAI fit?
TagoAI assembles the quality screens so your engineers stay on the process. Describe the view in the TagoAI panel, for example "a pasteurizer board per plant, quiet while heating water sits on the clean-plate line, flagging any unit running hot", and TagoAI builds the widget and its code against live devices; in the page's sample it flags the pasteurizer running 3 degrees over clean. Verify its output against device data before a plant sees it.
## Traceability is the quiet upsell
Once records exist per batch, recall economics change shape. A contamination question that once meant quarantining a production week narrows to the batches whose records intersect the suspect window, with the holding temperatures and CIP evidence attached. For your customer that is risk removed from the balance sheet; for you it is the reason the records subscription never gets cut in a budget review. It also deepens with the fleet: fouling rates and CIP results compared across every plant running your machines tell you which water chemistry eats plates and which recipes stress which components, knowledge that, as we argued in [What Makes a Moat in IoT](https://tago.io/blog/what-makes-a-moat-in-iot), only the maker with the installed base can hold.
## Frequently asked questions
**Can machines already running in plants be connected?** Yes. Add-on sensors for temperature, pressure, current or flow retrofit over LoRaWAN, cellular, satellite or other supported networks. New machines send from the controller over MQTT or HTTP.
**Does a proprietary controller format block us?** No. A payload parser converts it into named variables as each message arrives.
**Can each plant see only its own machines?** Yes. Access Management policies isolate every customer in a TagoRUN portal, branded with the Custom Domain & Whitelabel add-on and shipped as your own app with the Custom Mobile App add-on.
**How is per-liter billing computed?** An Analysis totals liters, batches or run hours per customer per month and posts the figures to your billing system over HTTP.
**Is the data trustworthy enough for an audit?** TagoIO runs on AWS in the US or the EU with a 99.9% uptime SLA for eligible accounts, ISO 27001 certified and GDPR compliant, with data encrypted in transit and at rest. Details at [tago.io/trust](https://tago.io/trust).
## Start with the machine the auditor checks first
For most makers that is the pasteurizer or the oven. Connect one, ship its records digitally for a quarter, and let the quality manager who stopped keeping binders make your reference call. The [Food Processing solutions page](https://tago.io/food-processing) walks the full path, and the free [QSR efficiency ebook](https://tago.io/ebooks/how-iot-drives-efficiency-in-qsr) shows where the downstream food world already took this playbook. Compliance pays for the infrastructure; everything you build on it is margin.
