# RisingHF LoRaWAN devices are now integrated with TagoIO
> Raleigh,NC,USA: TagoIO and RisingHF teams worked together to release a connector that makes the integration of the RisingHT temperature and humidity sensor very easy. Developers can create a free account at TagoIO and select the device from the list.
![RisingHF LoRaWAN devices are now integrated with TagoIO](https://tago.io/og/blog/risinghf-lorawan-devices-integration.png)
The first device, the Temperature and Humidity LoRaWAN sensor RHF1S001, offers a cost effective LoRaWAN end node solution for many applications. IP64 enclosure concept and water splash proof unique sensor design are ideal for outdoor use and installation in low accessibility locations.
Key specifications of the device:
Powered by lithium thionyl chloride battery: 5 years of operation for 1 uplink 2 minutes.
Extended industrial operating temperature: -40°C to +85°C.
Outdoor use: IP64 enclosure.
±5% RH typically from 20% RH to 80% RH at 25°C.
±0.5°C typically from +5°C to +60°C.
LoRaWAN compatible: Class A, uplink rate programmable from 2 minutes to 24 hours.
In a few clicks, the device is installed and a dashboard is added to the developer account. From there, developers can edit and create analytics, notifications (SMS, email, push notifications) as needed. The connector for the device is available for use right now.
Get the template of this dashboard here ([https://admin.tago.io/template/5c155bec93d838001dcc246b).](https://admin.tago.io/template/5c155bec93d838001dcc246b\).)
