# Script Editor is now integrated within TagoIO
> Try our new Script Editor available within the Analysis section. There is no need to work in a separated editor to create your scripts anymore. Also, you can try our code examples and modify them as needed to get the job done more quickly.
![Script Editor is now integrated within TagoIO](https://tago.io/og/blog/script-editor-is-now-integrated-within-tago.png)
Try our new **Script Editor** available within the Analysis section. There is no need to work in a separated editor to create your scripts anymore. Also, you can try our code examples and modify them as needed to get the job done more quickly.
Learn more about how to use the Editor here
![script-editor-analysis-scripts-TagoIO-dashboard](./images/script-editor-is-now-integrated-within-tago/QsuvBTAB7dTa9BKSXJL8EKQaew.png)
