# Sens'it is now fully integrated with TagoIO
> We are glad to announce the release of our complete integration of TagoIO with the Sigfox Sens'it device!
![Sens'it is now fully integrated with TagoIO](https://tago.io/og/blog/sensit-sigfox-integration.png)
### We are glad to announce the release of our complete integration of TagoIO with the Sigfox Sens'it device!
Now, you can easily add your Sens'it devices in a few clicks and get it running at TagoIO immediately. When you install the device, a dashboard is also added to your account so that you can edit it according to your needs.
According to Sigfox, the Sens'it for developers can be used as a devkit. Whether you are a digital or embedded software developer, or simply curious about IoT and Sigfox, you can build a complete solution using this great device and TagoIO.
When you are adding your device at TagoIO, you will find two device type options: **Sens'it v2** and **Sens'it v3**. Select the one you want to use.
Follow our new tutorial to get the most from your Sens'it with TagoIO: [Sens'it TagoIO Tutorial.](https://help.tago.io/portal/en/kb/articles/161-sens-it-with-sigfox)
**Sens'it Hardware main characteristics:**
The Sens'it device has several built-in sensors:
-   temperature and humidity,
-   luminosity,
-   accelerometer and magnetometer,
-   button,
-   reed switch (magnet detector).
    It also features two indicators:
-   RGB led,
-   white led.
More information about this device can be found at the Sens'it website.
