# The Best IoT Platform for Managing Thousands of Devices
> Scaling from ten IoT devices to thousands breaks fleet management, tagging, firmware updates, access control, and per-device cost. Here is the operational layer to evaluate.
![The Best IoT Platform for Managing Thousands of Devices](https://tago.io/og/blog/the-best-iot-platform-for-managing-thousands-of-devices.png)
Ten devices behave. You can name them, watch them, and fix them by hand. Vendors know this, which is why their demos look effortless and their headline numbers count devices in the millions.
The problem lives in the gap between those two. The jump from ten to thousands is where provisioning, tagging, firmware updates, access control, and per-device cost quietly break. None of that shows up at ten devices, and all of it decides whether you can run a real fleet. So evaluate the operational layer, not the marketing number.
## Provisioning at scale
At ten devices you add each one by hand. At thousands, manual provisioning is the bottleneck. You need to create, configure, and authenticate devices in bulk, and ideally let devices come online from a template without a human touching each one.
Ask: Can you provision devices by API or in batches? Is there a device template so a new unit inherits the right config automatically?
## Tagging and organization
A flat list of 3,000 devices is unusable. You need structure: tags for location, customer, hardware type, firmware version, and status, so you can filter, group, and act on slices of the fleet.
Tagging is also what makes everything else scale. Bulk actions, dashboards, and access rules all key off it. TagoIO uses a tag-based model for exactly this reason, so a single rule can target "all temperature sensors in the north region running firmware 2.1."
![Device and fleet monitoring in a TagoIO dashboard](https://tago.io/images/products/run/gallery-3.webp)
## Bulk operations and firmware updates
When something is wrong, you fix it across hundreds of devices at once, not one at a time. The same is true for firmware. A platform that cannot push an update or a config change across a tagged group will turn every fleet-wide fix into a multi-day chore.
Ask how bulk actions and over-the-air updates work, and whether you can stage them to a subset before rolling out to everyone.
## Data volume and the real cost model
Thousands of devices generate a lot of records, and that is where pricing surprises live. A model that looks fine at ten devices can become the largest line in your budget at scale.
Ask for a cost estimate at your target device count and data rate. Understand whether you pay by device, by data volume, by seat, or some mix, and which of those grows fastest for your use case.
## Access control and multi-tenant
At scale, more people touch the system, often across different customers. You need roles, scoped access, and clean separation between tenants so one client cannot see another's data and one mistake cannot touch the whole fleet.
If you serve multiple customers, multi-tenant separation is not optional. Score it as a requirement, not a nice-to-have.
## Monitoring the fleet itself
With thousands of devices, some are always offline, low on battery, or sending bad data. You need a view of fleet health, not just individual device dashboards, plus alerts when a group goes quiet.
Ask whether the platform can alert on a device that stops reporting, not only on the values it sends. Silence is often the most important signal.
## Where TagoIO fits
TagoIO is built around tags and an API-first model, so provisioning, organizing, and securing a large fleet are routine rather than heroic. The same platform that runs your ten-device pilot runs your ten-thousand-device deployment, and TagoDeploy gives you a dedicated single-tenant environment when scale or compliance calls for it.
Test it against your fleet on the [free plan](https://tago.io/pricing), or [book a demo](https://tago.io/request-demo) and bring your device count and data rate so the cost conversation is real.
