# The new Custom widget is here!
> Try out our new Custom Widget that allows you to add your own widget design into your dashboards.
![The new Custom widget is here!](https://tago.io/og/blog/the-new-custom-widget-is-here.png)
It more than an iFrame inside of your dashboard, you can add parameters and make it communicate with your devices, collect inputs from your end-users, and more. Just as a few ideas, now, you can use Google maps, Google Earth, or create your own map to display devices with geolocation.
The sky's the limit when using this widget. You can build your widget using Angular, React, Vue.js, or even plain old Javascript.
![Example of a custom widget created at TagoIO platform and dashboard](./images/the-new-custom-widget-is-here/kmNo2HwYzBwtL1HSFh68bUo989I.webp)
Start creating your own custom widget [here](https://help.tago.io/portal/en/kb/articles/450).
Share your experience and ideas in our [Community](https://community.tago.io/).
TagoIO Team.
