# The True Cost of a Mid-Market IoT Deployment: What You Actually Pay
> A line-by-line total cost of ownership map for a mid-market IoT deployment, plus a managed platform vs DIY on AWS comparison.
![The True Cost of a Mid-Market IoT Deployment: What You Actually Pay](https://tago.io/og/blog/true-cost-of-a-mid-market-iot-deployment.png)
Most IoT budgets get built the same way. Someone counts the devices, prices a sensor, adds a SIM plan, multiplies by the fleet size, and pads the number by twenty percent for safety. The board sees a clean figure. The project gets approved. Everyone feels good.
That number is almost always wrong. Not because the sensor price is wrong, but because the sensor is one of the cheapest parts of the whole thing.
If you are a project manager accountable for an IoT outcome, the costs that blow your budget are not on the hardware invoice. They are the costs nobody quotes you upfront, because they live in engineering hours, in platform fees that scale with usage, and in the slow drip of maintenance after launch. This article is a full total cost of ownership map. I want you to be able to defend your budget line by line, and to know exactly where a managed platform removes cost and where it does not.
## The part everyone budgets for
Let us start with the easy money, the part you already have a handle on.
Hardware is real and it is visible. A mid-market deployment might be a few hundred to a few thousand devices. You will price the sensor or gateway, you will price the SIM or the connectivity module, and you will get reasonably accurate quotes from vendors. There may be a markup for ruggedized enclosures or specific certifications, but hardware is a known quantity. You can get three quotes and pick one.
Connectivity per device looks small at the unit level. A few dollars a month per SIM, or a flat fee for a LoRaWAN or NB-IoT plan. PMs price this correctly per device.
These two lines are where most budgets stop being accurate. They are the visible tip. Below the waterline is where projects sink.
## The costs nobody warns you about
Here is the uncomfortable list. Every one of these is real, recurring or one-time, and routinely left out of the first budget.
### Platform and ingestion fees
Your devices send data somewhere. That somewhere costs money, and it usually scales with the number of messages, not the number of devices. A device reporting every fifteen minutes sends roughly 2,880 messages a day. Across a thousand devices that is nearly three million messages a day. Pricing that scales per message or per data point can grow faster than your device count, because the moment someone asks for "more frequent readings," your ingestion volume jumps without a single new device being installed.
This is a recurring cost. Budget it monthly, and budget it against your real reporting interval, not the demo interval.
### Payload parsing and integration engineering
This is the line that surprises people the most. Your device does not send clean, labeled data. It sends a compact binary payload, often hex, designed to keep the radio transmission short and the battery life long. Someone has to write code that turns that payload into "temperature: 4.2 degrees, battery: 87 percent, door: open."
That someone is an engineer, and every device model has a different payload structure. Change vendors, add a new sensor type, or get a firmware update that shifts the byte order, and you are paying for that work again. Then there is the integration in the other direction, pushing your data into the systems your business actually runs on, the ERP, the CMMS, the ticketing system, the billing platform. Every integration is custom engineering, and integration work is where timelines quietly slip by weeks.
This is mostly a one-time cost per device type and per integration, with a recurring maintenance tail.
### Dashboard and application building
The data has to become something a human looks at and acts on. A dashboard, an alert rule, a report, a mobile view for the technician in the field. This is real product work. It is design, it is frontend, it is the back and forth of "can we also show last week's trend." Underbudgeting here is common because it feels like the easy part. It is not. The application is the part your users actually touch, and it is the part they will ask you to change every month.
### Connectivity at scale
Connectivity is cheap per device and expensive in aggregate. Beyond the per-SIM cost there is the question of what happens when a thousand devices all try to reconnect after a network blip, or when your data volume crosses a tier and your rate changes. Connectivity providers have steps and overage charges. At small scale you never see them. At mid-market scale you will.
### Data egress
This one hides well. Moving data out of a cloud, between regions, or into a third-party system often carries a per-gigabyte egress charge. It is invisible during a pilot with ten devices. With a full fleet sending continuously, egress becomes a line you actually notice on the monthly bill.
### Ongoing maintenance and support
Software is never finished. Security patches, library updates, API changes from your connectivity provider, a new device model that needs onboarding, an alert rule that needs tuning. If you built the stack yourself, this is your engineering team's time, forever. If something breaks at 2 a.m., someone is on call. Maintenance is the single most underestimated recurring cost in IoT, because at budget time the system does not exist yet and nobody is thinking about year two.
### Staff time
Every hour your team spends on the IoT stack is an hour not spent on the product your company actually sells. A PM coordinating, an engineer parsing payloads, an ops person watching dashboards. This is a real cost even when it does not show up as an invoice, and it is the cost your finance team will ask about when they see the headcount.
### Scaling steps
Costs in IoT are not smooth. They jump. You add the hundredth device and nothing changes. You add the thousandth and suddenly you need a bigger database tier, a load balancer, a second region, a dedicated support contract. These steps arrive without warning and usually at the worst time, right when the project is succeeding and leadership wants to expand.
## One-time versus recurring, in plain terms
Sort the costs into two buckets and the picture gets clearer.
One-time costs: hardware, initial payload parsing per device type, first build of each integration, the initial dashboard and application build, and the setup and configuration of the platform.
Recurring costs: connectivity per device, platform and ingestion fees, data egress, ongoing maintenance and support, staff time, and the scaling steps that turn into new recurring tiers.
The mistake that kills budgets is treating recurring costs as if they were one-time. The build is a moment. The running is forever. A project that looks affordable as a one-time build can become a problem when year two and year three arrive with their full recurring weight and no new value to show the board.
## The cost of getting it wrong
There is one more cost, and it is the largest of all. It is the cost of a deployment that fails or stalls.
A project that runs six months over schedule because integration engineering was underbudgeted does not just cost the extra engineering. It costs the delayed value the project was supposed to deliver, the credibility of the team that promised it, and sometimes the appetite of the business to try IoT again at all. The most expensive IoT project is the one you have to rebuild because the first version could not scale or could not be maintained.
That is the real reason to map costs honestly. Not to make the number smaller, but to make it true, so the project survives contact with year two.
## Managed platform versus DIY on AWS
Here is the comparison that actually decides the budget.
If you build directly on raw cloud infrastructure, you assemble the pieces yourself. A message broker, a database, a rules engine, dashboards, user management, and the glue code between all of them. You own every line. You also own every patch, every scaling step, and every 2 a.m. page. The infrastructure bill can look low, but the engineering payroll is the real cost, and it never stops.
A managed IoT platform like TagoIO removes most of the hidden engineering cost. The ingestion, storage, device management, user and tenant management, dashboards, and alerting are already built and already maintained. Payload parsing is handled with a configurable layer rather than a custom service you maintain forever. You can see how the parsing and data structure works in the [TagoIO documentation](https://docs.tago.io). Pricing is predictable and tied to usage you can model in advance, which you can review on the [TagoIO pricing page](https://tago.io/pricing).
The trade is simple. With a managed platform you pay a clearer recurring fee and you stop paying for the engineering team that would otherwise build and maintain the plumbing. For a mid-market project, where you have a few hundred to a few thousand devices and a small team, that trade almost always favors the managed platform. The hidden engineering cost is the thing that was going to break your budget, and that is exactly the cost a managed platform takes off your plate.
## When TagoIO is the wrong choice
I am not going to pretend the managed platform wins every time, because it does not.
If you already run a large in-house cloud engineering team, you need total control of the infrastructure, and you are operating at very large device counts, building directly on AWS IoT Core can be cheaper at scale. At a high enough volume, the per-message economics of raw infrastructure beat a managed platform's pricing, and if you already employ the engineers who would maintain it, you are not adding that cost, you already carry it. In that situation, AWS IoT Core is the rational choice, and you should choose it with the same eyes-open budgeting this article argues for.
The dividing line is honest and simple. If your scale is mid-market and your team is small, the hidden engineering cost is your enemy and a managed platform removes it. If your scale is very large and you already own a cloud engineering team, raw infrastructure can win on unit economics. Most mid-market projects are firmly in the first camp, which is why managed platforms exist.
## What to do with this
Build your budget in two columns, one-time and recurring, and put every line from this article in one of them. Use your real reporting interval, not the demo interval. Price maintenance for year two and year three, not just the build. Then run the managed versus DIY comparison against your actual device count and your actual team size.
If you do that, you will walk into the budget meeting with a number you can defend line by line. And when year two arrives, the project will still be standing.
