# When to Choose TagoIO Over AWS
> Discover when TagoIO is a better alternative to AWS for IoT projects, offering faster development, predictable costs, built-in dashboards, and a simpler all-in-one platform.
![When to Choose TagoIO Over AWS](https://tago.io/og/blog/when-to-choose-tagoio-over-aws.png)
## **When TagoIO is the Better Choice**
## **Rapid Development and Prototyping**
TagoIO excels when you need to get an IoT solution up and running quickly. While AWS requires extensive configuration of multiple services (IoT Core, Lambda, DynamoDB, CloudWatch, etc.), TagoIO provides an integrated [platform](https://tago.io/blog/what-is-and-is-not-an-iot-platform) where devices, data storage, visualization, and analytics work together out-of-the-box. What might take weeks to configure on AWS can be accomplished in hours with TagoIO.
## **Small to Medium Scale Deployments**
For projects handling thousands to tens of thousands of devices, [TagoIO](https://tago.io/blog/how-tagoio-works) offers a sweet spot of functionality without over-engineering. AWS's microservices architecture, while suited to massive scale, introduces unnecessary complexity for smaller deployments. TagoIO's unified platform eliminates the need to orchestrate multiple AWS services, reducing both development overhead and operational complexity.
## **Cost Predictability and Budget Control**
AWS's pay-per-use model across dozens of services can lead to unpredictable costs and bill shock. TagoIO's transparent, tier-based [pricing](https://tago.io/blog/how-much-will-your-iot-application-cost-a-complete-guide-to-tagoio-pricing) makes budgeting clear. You know exactly what you'll pay monthly, eliminating the complexity of estimating costs across IoT Core message charges, Lambda execution time, DynamoDB read/write units, S3 storage, and CloudWatch metrics.
## **TagoIO's Key Advantages**
-   **All-in-One Platform:** Complete IoT stack in a single platform, with device management, data storage, visualization, analytics, and user management all integrated.
-   **Built-in Data Visualization:** Drag-and-drop dashboards with real-time widgets. No need to build custom front-ends or integrate separate BI tools like QuickSight.
-   **Simplified Device Management:** Intuitive device provisioning, configuration, and monitoring without the complexity of AWS IoT Device Management and Fleet Provisioning.
-   **Pre-built Integrations:** Ready-made connectors for popular IoT protocols (LoRaWAN, Sigfox, NB-IoT) and third-party services, reducing integration development time.
-   **Faster Time-to-Market:** Complete IoT applications can be deployed in days rather than months, with minimal custom development required.
-   **Lower Learning Curve:** Single platform to master instead of learning and orchestrating multiple AWS services. Ideal for smaller teams without dedicated DevOps resources.
-   **Transparent Pricing:** Clear, predictable monthly costs based on usage tiers, eliminating the complexity of estimating charges across multiple AWS services.
-   **Embedded Analytics Engine:** Built-in serverless compute for data processing, analysis, and automation without managing Lambda functions and their dependencies.
-   **White-Label Capabilities:** TagoRUN allows easy creation of branded IoT applications for end customers without building custom front-ends.
-   **ISO27001 Certified:** TagoIO maintains ISO27001 certification, with enterprise-grade security and compliance standards built into the platform by default.
-   **TagoDeploy for Enterprise:** Dedicated instances through TagoDeploy provide enterprise-grade isolation and performance at aggressive pricing, perfect for medium-sized applications requiring dedicated resources.
# **Detailed Feature Comparison**
To help you make an informed decision, here's a side-by-side comparison of TagoIO and AWS across key IoT development factors:
| Feature | TagoIO | AWS IoT |
| Setup Complexity | Simple, all-in-one setup | Complex, multiple services |
| Time to Market | Days to weeks | Weeks to months |
| Data Visualization | Built-in drag-and-drop dashboards | Requires custom UI development |
| Mobile App | Ready-made mobile app available for free | Must build from scratch |
| Pricing Model | Transparent monthly tiers | Pay-per-use across multiple services |
| Device Management | Intuitive web-based interface | CLI and console-based |
| Learning Curve | Low: single platform to learn | High: multiple services to master |
| Data Analytics | Built-in serverless functions | Lambda + additional services needed |
| Protocol Support | LoRaWAN, Sigfox, NB-IoT, HTTP, MQTT | MQTT, HTTP, custom protocols |
| User Management | Built-in with TagoRUN white-label | IAM + Cognito setup required |
| Real-time Notifications | Built-in email, SMS, push notifications | SNS + SES integration needed |
| API Development | Full REST APIs ready | API Gateway + custom development |
| Security Compliance | ISO27001 certified | Multiple certifications available |
| Data Storage | Integrated time-series database and entity | DynamoDB, RDS, S3 configuration |
| Scalability | Excellent for small to medium scale | Virtually unlimited scale |
| Support & Documentation | Dedicated IoT-focused support | Extensive but general cloud docs |
| Enterprise Options | TagoDeploy dedicated instances | Enterprise Support Plans available |
| Global Infrastructure | Multi-region availability with 15+ locations | Global presence with 25+ regions |
| Best For | Rapid development, predictable costs, SMB to Enterprise | Massive scale, custom solutions, organizations already on AWS |
## **When AWS Might Be More Appropriate**
While TagoIO excels in many scenarios, AWS remains the better choice for specific situations. [Consider](https://tago.io/blog/build-or-buy-an-iot-platform) AWS when you're building massive-scale IoT deployments with millions of devices, require deep integration with existing AWS infrastructure, need highly specialized compute resources, or have specific compliance requirements that necessitate complete control over the underlying infrastructure. AWS is also preferable when you have a large DevOps team capable of managing complex microservices architectures, or when your project requires custom-built solutions that don't fit into TagoIO's platform model. If your organization already has significant AWS expertise and tooling, using that existing knowledge might outweigh TagoIO's simplicity advantages. However, it's important to remember that AWS doesn't provide built-in dashboards for data visualization or ready-made mobile applications. These would need to be developed separately, adding significant development time and costs to your project.
## **Making the Right Choice**
The choice between TagoIO and AWS ultimately depends on your project's scale, timeline, team expertise, and budget constraints. TagoIO shines when you prioritize rapid development, cost predictability, and operational simplicity. It's particularly well-suited for startups, small to medium enterprises, and any organization that wants to focus on their core IoT application rather than managing complex cloud infrastructure. By choosing TagoIO, you're not just selecting an IoT platform: you're choosing faster time-to-market, predictable costs, and the ability to focus on what matters most: delivering value to your customers through innovative IoT solutions.
