Now you can embed any of the widgets available from TagoIO into your website. Just select the ‘Embed Widget’ tab inside the widget, generate the code, and copy into your webpage.
Embedded widget will also show the data in realtime!
Check it out! Chicago Bus in realtime on this static blog!
