New general settings for Decimal Separator
Try new features using the Beta option available in your TagoIO admin account. We will be releasing new features and changes that will be available for those customers that enable the 'Beta' option.
Final users and developers have the option to define the Decimal Separator that is applied to the values shown in the dashboards: “comma” or “dot”. It will define if a number would be displayed as 1,234.56 or 1.234,56.
The Decimal Separator option is located in your Account Settings, under the Visualization Preferences tab. You can get to your settings by using this link: https://admin.tago.io/account/
Make sure that you use data format as Number wherever possible, so that your users will be able to get the benefit of the auto adjustment of the decimal separator based on their own settings.
Decimal Separator Settings for TagoIO dashboard
Notice: This setting doesn’t impact the format of the data stored into the data buckets or when it is exported and downloaded to files like .csv, .xls, JSON format: the “dot” is the standard for decimal representations.
