If you were around in the early 1980s, you might remember the breathless predictions about personal computers. They would revolutionize every business, transform every home, and usher in a new era of productivity. TIME Magazine named the PC its “Machine of the Year” in 1982. Venture capital poured in. Every company scrambled to figure out their “computer strategy.”
And then… not much happened. At least not for a while. Sound familiar?
The Pattern We’ve Seen Before
Those of us working in IoT today are living through a similar moment. The hype has been enormous. Predictions of 50 billion connected devices. The “Fourth Industrial Revolution.” Billions in venture funding. Every major tech company was launching IoT platforms.
And yet, most organizations still struggle to articulate clear ROI for their IoT projects. Pilots remain stuck in “proof of concept purgatory.” The transformative productivity gains remain stubbornly out of reach.
This isn’t a failure of IoT. It’s the natural pattern of truly transformative technologies.
The PC Revolution That Wasn’t (Until It Was)
Go back to the 1980s. Personal computers were expensive: $3,000 to $5,000 in 1980s dollars, equivalent to $10,000-$15,000 today. Software was limited, clunky, and required significant technical expertise. Most businesses that bought computers couldn’t really articulate what to do with them.
The productivity gains? Hard to measure. Often negative at first, once you factored in training time, compatibility issues, and workflow disruption.
In 1987, economist Robert Solow famously quipped: “You can see the computer age everywhere but in the productivity statistics.”
It took nearly 10-15 years from the peak of PC hype to widespread, measurable value creation. The transformation didn’t really accelerate until the early-to-mid 1990s, when better software, networking, trained users, and redesigned workflows finally converged.
The IoT Revolution That Isn’t (Until It Will Be)
IoT in the 2020s follows a strikingly similar trajectory. We have the hype. We have the investment. We have impressive technology.
What we often lack:
Clear use cases. Many organizations know they should “do IoT” but can’t articulate specifically what problem it solves.
Integration with existing systems. Connecting sensors is the easy part. Integrating that data into legacy enterprise systems is costly and complex.
Skills and expertise. Few teams can build end-to-end IoT solutions without significant external help.
Actionable insights. Data gets collected but rarely translated into decisions that drive value.
Why Transformative Technologies Stall
The parallels between 1980s PCs and 2020s IoT reveal a consistent pattern:
| Challenge | 1980s PCs | 2020s IoT |
| Hardware cost and maturity | Expensive, underpowered, incompatible | Sensors cheap, but connectivity and power challenges remain |
| Software and platforms | Fragmented, difficult to use | Too many platforms, limited interoperability |
| Standards | No common OS or file formats | Competing protocols (LoRa, NB-IoT, Zigbee, cellular) |
| Skills gap | Few people knew how to use computers | Few teams can build complete IoT solutions |
| Unclear value proposition | “What do I actually do with this?” | “We have data, now what?” |
| Integration burden | Didn’t fit existing workflows | Doesn’t fit existing enterprise systems |
The technology itself was never the limiting factor. The environment around the technology was.
What Finally Unlocked PC Value
The PC didn’t become indispensable because the hardware got better. Value emerged when everything around it matured:
Standardization around IBM-compatible hardware and DOS/Windows reduced fragmentation
Killer applications like Lotus 1-2-3, WordPerfect, and eventually Microsoft Office solved real problems
Networking and email connected workers and made collaboration possible
Falling prices made adoption economically viable for smaller businesses
A trained workforce: a generation that grew up with computers entered the job market
What Will Unlock IoT Value
We’re seeing similar enablers emerge for IoT:
AI and machine learning are making sense of sensor data automatically, turning raw data into actionable insights
Low-code and no-code tools are lowering the skills barrier
Cellular IoT (LTE-M, NB-IoT) is simplifying connectivity decisions
Proven ROI case studies are giving others a blueprint to follow
The Uncomfortable Truth About Timing
Here’s what the PC experience teaches us: transformative technologies don’t deliver value just because they exist. They require hardware, software, services, and talent working together in a mature, integrated way. They require clear use cases that focus on what’s valuable, not just what’s possible. They require workflow integration, because technology must fit how people actually work. They require economic viability, where the total cost of ownership makes sense. And they require time for organizations to learn, adapt, and redesign processes.
The PC took 10-15 years to move from hype to productivity engine. IoT is likely on a similar timeline, and we’re probably somewhere in the middle of that journey.
The Optimistic View
This should actually be encouraging.
The PC eventually became so essential that we can’t imagine business without it. Not because the technology changed so much, but because the world adapted to make it useful.
IoT is following the same path. The sensors, connectivity, and platforms we have today are more than capable of delivering value. The industry is maturing. The use cases are becoming clearer. The integration challenges are being solved.
The companies building real IoT solutions today, not chasing hype but solving specific problems, will be exceptionally well-positioned when the broader market catches up.
The transformation is coming. It’s just taking the same winding path that every truly transformative technology takes.
At TagoIO, we’ve watched this evolution unfold and built our platform with these realities in mind. Rather than chasing hype or forcing customers into rigid frameworks, we focused on what actually matters: giving developers and enterprises the tools to move from pilot to production without hitting the walls that stall most IoT projects. Our approach layers sophistication: start simple, scale without migration. From developers prototyping their first connected device to enterprises deploying thousands of sensors across global operations, the platform grows with you instead of forcing a rip-and-replace.
We believe IoT value comes from reducing friction, not adding it. That means flexible data handling, capable analytics, integrations that work with your existing systems, and infrastructure that scales globally without complexity. If you’re tired of pilots that never graduate or platforms that promise everything and deliver dashboards, we’d love to show you a different path. Visit tago.io to see how we’re helping companies turn connected devices into real business outcomes.
