For years, the IoT industry has been obsessed with a single strategic question: should we build our own platform or buy one?
It seemed like the right question. Build meant control, flexibility, and owning every layer of your stack, but also enormous cost, long timelines, and engineering teams buried in infrastructure work that had nothing to do with your actual business. Buy meant speed and simplicity, but also vendor dependency, limited customization, and the fear of handing over the keys to something critical.
The problem is that this framing no longer reflects reality. And teams that are still debating it are wasting time on the wrong conversation.
Why “Build vs. Buy” Is the Wrong Frame
The premise of the old debate was that buying a platform meant surrendering control. That was never fully true, and today it’s almost entirely false.
Modern IoT platforms are not finished products you consume passively. They are full development environments where you build real systems, with control over code, automation, visualization, user access, and integrations, all in one place. You are not buying a black box. You are choosing your infrastructure layer so you can invest your energy in everything above it.
Think about what you actually own when you build on a platform like TagoIO: your business logic, your data models, your automations, your dashboards, your user experience, your brand, your customer relationships. The platform handles device connectivity, data ingestion, time-series storage, multi-tenancy, and security, the layers that are essential but not differentiating.
So if you’re still building in-house because you’re afraid of losing control, the question worth asking is: control of what, exactly?
The Real Question: Where Should You Invest Your Differentiation?
The debate has shifted from build vs. buy to something more precise and more useful:
What parts of your IoT solution are uniquely yours, and worth investing engineering capital to own?
Everything else is commodity. And spending months building commodity infrastructure is not a competitive advantage. It is a tax on your roadmap.
This reframe matters for several reasons:
It aligns IoT decisions with business strategy. Technology choices should follow identified business problems, not precede them. Teams that start by asking “what pain are we solving, and for whom?” make better platform decisions than teams that start by debating architecture. When the business problem is clear, the question of what to build versus what to operate becomes almost self-evident.
It removes false trade-offs. The assumption that control requires building from scratch is no longer valid. Platforms today give you full programmatic access to your data and logic. You can build custom parsers, decode sensor data, and monitor thousands of devices from one dashboard, without vendor lock-in. That is not a concession. That is real power.
It accelerates learning. Early in a project, you often don’t know what you’ll eventually need to own. A platform lets you reach real users, prove value, and then make informed decisions about what’s worth internalizing, rather than betting heavily upfront on assumptions that may not survive contact with the market.
The Control Problem Is Largely Solved
Before looking at real-world examples, it is worth addressing the concern that still holds some teams back: the fear of losing control by adopting a platform.
This concern was legitimate a decade ago. Early IoT platforms were opaque, rigid, and proprietary. Your data lived in someone else’s schema. Your logic ran in black-box workflows you couldn’t inspect or extend. Your product was constrained by whatever the vendor decided to support. Choosing a platform often meant accepting a ceiling on what you could build.
That world has changed substantially. Today, a platform like TagoIO is built around the assumption that you need to own what matters to your business, and it is designed to make that possible.
Your code is your code. The scripts, automations, and business logic you write inside TagoIO belong entirely to you. There is no proprietary language that traps your logic on one vendor’s platform. You write in JavaScript, you use standard APIs, and you can take that logic with you. Your integrations are your integrations. Reliable APIs and a full SDK let you connect your applications to any third-party system, on your terms, following your architecture decisions. Your IP is your IP. The dashboards, the data models, the user experience, the brand, everything visible to your customers is yours. With white-label configuration, your customers interact with your domain, your colors, your logo, with no trace of the underlying platform. Your data is your data. You define the schema, you control retention, you own the export. The platform stores it efficiently; you decide what to do with it.
What a modern platform removes is not control, it is undifferentiated work. The concern has not disappeared entirely, and vendor selection still matters. But for teams building serious IoT products today, the question is no longer whether a platform will let them maintain control. It is whether they are being strategic about where they exercise it.
What This Looks Like in Practice
The companies winning in IoT today are not the ones who built the most from scratch. They are the ones who were precise about where their differentiation lives, and ruthless about not wasting engineering cycles on everything else. Here are three examples from TagoIO customers that illustrate this clearly.
ProSentry: Start With the Problem, Own the Solution
ProSentry, a smart-building risk-prevention platform, began by identifying a clear gap in facility management, especially around detecting water and gas leaks. Rather than starting with sensors, they focused on defining the specific risks that needed mitigation. Only once the problem was precisely framed did the technology decisions follow.
Founded in 2019 in New York, ProSentry delivers full-building risk mitigation platforms for commercial and multi-family properties, integrating IoT sensors that monitor water, gas, oil, environmental conditions, and mechanical systems, offering building-wide visibility and real-time alerts.
With the TagoIO platform, ProSentry built a system that connects water, gas, and environmental sensors across entire buildings and rapidly added new monitoring features in response to regulatory changes and customer needs. Onboarding used QR-code setup and automated registration, letting buildings self-manage installation while ProSentry focused on what they do best: solving the risk problem.
The result: ProSentry shifted building management from a reactive process to a proactive strategy, centralizing data from multiple sensors into one intuitive platform, enabling faster decision-making, reduced insurance costs, and support for compliance with evolving regulations.
ProSentry owns the domain expertise, the customer relationship, the risk logic, and the product. TagoIO owns the infrastructure. That is a sensible division of investment, and it started by asking the right question first.
NOVUS: From Hardware Manufacturer to IoT Platform Provider
NOVUS is a measurement and control equipment specialist serving clients across more than 50 countries. Their core expertise is industrial instrumentation, not cloud infrastructure. Rather than divert years of engineering effort into building a cloud platform from scratch, they built on top of TagoIO and launched NOVUS Cloud, a fully branded IoT solution for their industrial clients.
The result was decisive. NOVUS reduced the time required to deploy tailored monitoring solutions from months to weeks, enabling rapid response to diverse client requirements. Their clients gained real-time visibility into silo management, mining operations, and industrial processes, capabilities that would have taken years to build independently. NOVUS successfully diversified its business model beyond traditional hardware sales to include complete IoT monitoring services, opening new revenue streams.
What NOVUS owns is their domain expertise, their customer relationships, their hardware, and their branded solution. What they operate is the infrastructure layer. That is a sensible division of investment.
Igua: Critical Infrastructure at Scale, Without Compromise
Igua Saneamento provides water and sanitation services to over 7 million people across 121 municipalities in Brazil, a context where operational control is not optional, it is a regulatory obligation.
Before implementing TagoIO, the company operated with no real-time visibility into their distribution infrastructure, identifying network breaks and pressure drops only after receiving customer complaints. The scale of the challenge, thousands of sensors across dispersed operations, made a from-scratch build both slow and prohibitively expensive.
By building on TagoIO, Igua established a complete Operations Control Center in under 60 days with approximately 70% cost reduction compared to traditional telemetry solutions. They integrated multiple connectivity protocols including LoRaWAN, 4G, and NB-IoT. They own the dashboards, the alerting logic, the operational workflows, and the data. The platform owns the plumbing. That distinction allowed them to move fast without sacrificing the control that public infrastructure demands.
Start With the Problem, Not the Platform
There is one more dimension to this reframe that matters deeply: the best IoT projects do not start with a technology decision at all.
They start with a business problem. A gap in operational visibility. A risk that is costing money. A process that is still running on paper. The technology, including the platform choice, comes after that clarity exists.
When you start with the problem, the question of what to build and what to operate becomes practical rather than ideological. You know what makes your solution valuable to customers. That tells you what is worth building. Everything else is a platform decision.
The old question was about technology. The new question is about strategy.
