Business
How to Avoid Overcomplicating Your IoT Platform Choice
Why IoT platform evaluations stall on 80-row spreadsheets, which decisions are hard to reverse, and how a two-week pilot on real devices replaces the RFP.
Thiago Lima ·
Most teams start an IoT platform evaluation the sensible way. A shortlist of three or four candidates, a spreadsheet, and requirements from every stakeholder: SSO and audit logs, alerting and firmware management, a cost model, a portal for customers. It looks like diligence, and for the first two weeks it is.
Then the spreadsheet hits 80 rows. Every vendor ticks most boxes, because every mature platform can store telemetry, draw a chart, and send an alert. The differences that remain sit in rows nobody can score without using the product, so the team schedules more demos. Three months in, the evaluation has a weighted scoring model, four vendor decks, and no devices sending data anywhere.
The complexity has two sources, and neither is the vendors. The first is evaluating features you will not use in year one. The second is treating the decision as irreversible, which makes every row feel like it has to be right. Most rows do not. A short list of things is hard to change later. Everything else is configuration, and configuration is what a pilot is for.
Cut the evaluation to what is hard to reverse: an 80-row requirements spreadsheet where every vendor scores 82 to 91 percent narrows to the questions that are hard to reverse, bulk data export, pricing at year-three volume, a branded portal for end users, the devices you actually have, and your own code inside the platform, then ends in a two-week pilot on real devices
Signs you are overcomplicating it
A few patterns show up in almost every stalled evaluation I have seen from system integrators and OEM product teams.
  • The requirements list has rows for features nobody can name a use for in the next twelve months. Digital twins appear in the spreadsheet while the actual devices are 40 LoRaWAN temperature sensors in a warehouse.
  • Every vendor scores between 82 and 91 percent. When the spread is that narrow, the scoring measures how well each vendor writes datasheets.
  • Nobody on the evaluation team has logged into any candidate for more than an hour.
  • The words “future-proof” appear in the justification document and nobody can define the future it is proofing against.
  • A second RFP round is being discussed to “clarify the responses” from the first.
  • The pilot start date has moved at least twice.
If two or more of these fit, the spreadsheet is no longer helping.
What is truly irreversible
The useful question for each row is not “does the platform do this” but “if we get this wrong, what does it cost to change our mind in two years?” Most rows fail that test. Widget types, alert channels, report formats, user roles, dashboard layouts, and the ERP integration are all things you configure and reconfigure for as long as you use the platform. Getting them wrong at selection time costs an afternoon later.
A short set of decisions does not work that way, and those deserve the evaluation time.
Data ownership and export. Two years of telemetry is the most expensive asset in the project, and whether you can get it out in bulk, in a usable format, without a support ticket, decides how strong the vendor’s position is at renewal. Check how data export works, whether the API gives raw access to everything, and where the data lives. The vendor lock-in post covers what to test.
Pricing behavior at year-three volume. The price at 50 devices tells you nothing. Model the bill at the device count and message rate you expect in year three, and find which meter moves the number: devices, data points, storage, users, or something else. Two platforms that cost the same today can differ by a factor of three at scale, and switching later means migrating the data from the previous paragraph. The three-year pricing comparison walks through the math.
Who your end users are. If the people looking at the data are your own operations team, the admin console is enough. If they are customers, tenants, or field technicians who must never see each other’s sites, the platform has to put a branded portal in front of them with per-user access rules. That is architecture, not cosmetics. On TagoIO that layer is TagoRUN with Access Management policies; building it yourself after the fact is a project, not a setting.
The devices and networks you actually have. Not the ones you might add in 2028. If the fleet is LoRaWAN through a specific network server, cellular devices speaking MQTT, or a legacy Modbus gateway, the platform needs to decode those payloads today.
Integration surface. Can your own code run inside the platform when a rule outgrows a menu, and can external systems call in and out through a documented API? That is the difference between a platform you extend and one you work around.
That is the whole list. If a candidate passes, the remaining rows are configuration you will verify in the pilot, and configuration is not a reason to keep the evaluation open.
Replace the spreadsheet with a two-week pilot
The spreadsheet answers questions by reading. The pilot answers them by doing, and doing is faster once the hard-to-reverse questions are settled. The format that works is narrow and time-boxed: one use case that matters to the business, ten to twenty real devices from your fleet, one site, one type of user, and a fixed end date two weeks out. Write down what “worked” means before you start: devices decoded and sending data, one dashboard the intended user can read, one alert that fires on a real condition, one export of the collected data your team can open.
On TagoIO the two weeks tend to go like this. Days one and two: add the devices through a Connector for your network, or write a Payload Parser if the device is not in the list. Days three to five: build the dashboard with standard Widgets, then convert it to a Blueprint Dashboard so one layout serves every device. Week two: an Action that sends the alert, an Analysis script if the logic needs more than a threshold, and a TagoRUN user logging in to see only their own data. On the last day, export the data and read the bill.
What you learn in those two weeks is what the spreadsheet could not tell you: how long decoding a new device really takes, whether the intended user understands the dashboard without training, whether the pricing meters move the way you modeled, and how the platform behaves when your Analysis code throws an error at 2 a.m. The buyer’s guide has the questions to ask vendors before this stage; the pilot is where you stop asking and check.
When the right answer is a small trial, not another RFP
Some versions of this decision do not need a procurement process at all. If you are a system integrator choosing a platform for your own service business, or a product team with a few hundred devices in year one, a wrong choice costs a migration you can do in a quarter. In that situation, the most expensive part of the decision is the time spent making it.
A free or low-tier account on two candidates, the same ten devices connected to both, and two weeks of real use will produce a clearer answer than a third round of vendor questionnaires. Building on AWS IoT Core or an open-source stack is a legitimate answer for some teams, and the same test applies: connect the devices and count the weeks to a working dashboard.
Then decide, and write down why. The reasons that will matter in two years are the hard-to-reverse ones. Everything else you will change at least twice anyway.
Resources
