The Things Network (TTN) is one of the most widely used LoRaWAN network servers in the world, running on The Things Stack v3. It handles device registration, LoRaWAN MAC-layer communication, and payload routing. TTN is excellent at the network layer, but it is not an application platform. It does not store your data long-term, build dashboards, or trigger alerts based on sensor values.
TagoIO is the application platform that completes the stack. It stores time-series data, drives interactive dashboards, fires alerts, runs serverless analysis scripts, and exposes a full REST API.
Connecting TTN to TagoIO is a clean, well-supported integration. TagoIO has a native TTN v3 connector that handles the webhook automatically.
- A TagoIO account (free plan available)
- A TTN account at console.cloud.thethings.network
- At least one registered end device in a TTN application
- A working LoRaWAN gateway with TTN coverage
Architecture overview
[LoRaWAN sensors] → [LoRaWAN gateway] → [TTN v3 LNS] → (HTTPS webhook) → [TagoIO]
Every uplink flows through TTN’s network server, which authenticates it and delivers the application payload to the webhook you configure. TagoIO receives that payload, runs your parser, and stores the resulting variables.
Step 1: Create a device in TagoIO using the TTN connector
- Log in to admin.tago.io.
- Click Devices → Add Device.
- Search for The Things Network v3 in the connector catalog.
- Name the device to match your TTN end device.
- Click Create Device.
TagoIO displays a Webhook URL and an Authorization Token. Copy both.
Device documentation: docs.tago.io/docs/tagoio/devices
Step 2: Configure the TagoIO webhook in TTN
- In your TTN Application, go to Integrations → Webhooks.
- Click + Add webhook → Custom webhook.
- Set Base URL to the TagoIO Webhook URL.
- Under Headers, add:
Authorization: YOUR_TAGOIO_TOKEN - Enable Uplink message events.
- Save.
Step 3: Write a Payload Parser
TTN sends a JSON object on each uplink. TagoIO expects variables in its standard format:
[{"variable": "temperature", "value": 22.5, "unit": "C"}]
Option A: Use TTN payload formatter (decoded_payload)
If TTN is decoding your payload, map the decoded fields:
if (!decoded) { payload = []; return; }
payload = Object.entries(decoded).map(([key, value]) => ({
variable: key, value: value
Option B: Decode raw bytes in TagoIO
For raw base64 payloads (Cayenne LPP example):
const temperature = raw.readInt16BE(2) / 10;
const humidity = raw.readUInt8(5) / 2;
payload = [
Adding RF metadata:
const rxMeta = payload.uplink_message.rx_metadata?.[0] || {};
payload.push({ variable: "rssi", value: rxMeta.rssi });
payload.push({ variable: "snr", value: rxMeta.snr });
Payload Parser docs: docs.tago.io/docs/tagoio/devices/payload-parser
Step 4: Verify in the Live Inspector
Open the Live Inspector on your device page and confirm that decoded variables arrive on the next uplink.
Live Inspector docs: docs.tago.io/docs/tagoio/devices/live-inspector
Step 5: Scale to a fleet
For large fleets, create one TagoIO device per TTN end device, or use a single TagoIO catch-all integration with an Analysis script that routes incoming data by dev_eui.
For multi-device dashboards, Blueprint Dashboards apply one layout to all devices via tags automatically.
Analysis docs: docs.tago.io/docs/tagoio/analysis
Sending downlinks from TagoIO to TTN
Use a TagoIO Analysis script to POST downlinks via the TTN v3 API:
await axios.post(
`https://eu1.cloud.thethings.network/api/v3/as/applications/${APP_ID}/devices/${DEVICE_ID}/down/push`,
{ downlinks: [{ f_port: 1, frm_payload: Buffer.from([0x01]).toString("base64"), priority: "NORMAL" }] },
{ headers: { Authorization: `Bearer ${TTN_API_KEY}` } }
This lets you send commands to devices: change reporting interval, toggle a relay, request on-demand readings.
Taking it further with AI
TagoIO’s MCP server connects AI assistants like Claude to your device data. Ask: “Which devices haven’t reported in 6 hours?” or “Average temperature across all nodes in Building B?”
MCP docs: docs.tago.io/docs/tagoio/tago-ai/tagoio-mcp-ai-powered-iot-data-integration
Summary
The TTN-TagoIO integration uses TagoIO’s native TTN v3 connector. Register the device in TagoIO, add the webhook in TTN, write a payload parser, and your LoRaWAN data flows into long-term storage with full dashboard and alerting capabilities.
- Devices: docs.tago.io/docs/tagoio/devices
- Analysis Scripts: docs.tago.io/docs/tagoio/analysis
