At some point in the growth of almost every IoT system integrator, someone on the team says it: “We should just build our own platform.”
The logic seems sound. You know your vertical. You have opinions about what the platform should do. You are paying platform fees that feel like they should be going toward something you own.
This is where most SIs make an expensive mistake.
What “Building from Scratch” Actually Means
Building your own IoT platform is not one project. It is eight or ten projects running in parallel.
Here is what you are actually signing up for:
- MQTT broker: handles device connections at scale, manages disconnections, routes messages
- Device registry: tracks every device, its state, its metadata, its firmware version
- Payload parser: decodes binary or encoded sensor data into usable values
- Data pipeline: ingests, transforms, and stores time-series data
- Dashboard engine: renders charts, maps, and widgets in real time from stored data
- Multi-tenant data model: keeps client data isolated and secure across environments
- Alerting and automation: triggers actions based on data conditions
- API layer: exposes your platform to third-party integrations
- User management and access control: roles, permissions, audit logs
- Mobile app: iOS and Android, maintained across OS updates
Each of those is a real engineering project. Together, they represent 18 to 24 months of development time for a competent team, and a cost that industry estimates place between $900,000 and $3 million, before ongoing maintenance, security updates, and the engineering support burden that starts the day you ship device number one.
The Ongoing Cost Nobody Budgets For
Once the platform is live, someone has to maintain it. Patching security vulnerabilities, keeping up with LoRaWAN specification changes, updating mobile apps when iOS or Android release new versions, handling support tickets when a client’s device stops showing data.
This is engineering time that does not go toward new features, new clients, or the vertical expertise that differentiates your business.
Most SIs who build their own platform spend more time keeping the platform alive than building the solutions that sit on top of it.
When Building from Scratch Makes Sense
Building makes sense when:
The platform itself is what you are selling. Your business model is licensing a platform to other SIs or directly to end customers. The platform is the product.
You have requirements no existing platform covers. Very specific regulatory constraints, proprietary communication protocols, or data sovereignty requirements.
You have a dedicated platform engineering team with IoT experience. Not a software team that will learn IoT along the way.
If all three are true, build. If even one is not, the math changes quickly.
When Reselling Wins
For most system integrators, the value delivered to clients is domain expertise: knowledge of the vertical, relationships with hardware vendors, understanding of the client’s operational environment.
A managed IoT platform has already solved the MQTT broker, the device registry, the dashboard engine, and the multi-tenant data model. It has already built the mobile app and maintained it through four iOS versions. It is already ISO 27001 certified and handles security compliance on your behalf.
You add value on top: the vertical knowledge, the hardware integration work, the client relationship, and the solution design. That is where your margin is.
Delivery is faster. Iterations are faster. Scaling to new clients does not require rebuilding infrastructure.
Where TagoIO Fits in This Model
TagoIO is built for the resell model. System integrators build solutions on top of TagoIO, brand the client-facing experience with TagoRUN, and deliver it to clients under their own identity.
500+ device integrations, serverless Analysis scripts, multi-tenant environments, and white-label portals are all included. The integrator spends engineering time on what differentiates the solution.
For SIs evaluating this model: https://tago.io/partners
Next Steps
- Explore the partner program: https://tago.io/partners
- See TagoRUN for client-facing portals: https://tago.io/run
- Browse real-world use cases: https://tago.io/use-cases
