Kerlink is a French LoRaWAN infrastructure vendor with a strong presence in smart city, utility, and industrial deployments. Their Wirnet iStation (industrial outdoor), Wirnet iFemtoCell (indoor), and Wirnet Station devices are known for build quality and carrier-grade reliability. Kerlink also operates the Wanesy Management Center, a cloud-based LoRaWAN network server.
TagoIO sits at the application layer: it receives device data, stores it, and lets you build dashboards, alerts, and automations. Connecting Kerlink to TagoIO means wiring the Kerlink network server output to TagoIO’s data ingest endpoint.
This guide covers two paths: Kerlink Wanesy Management Center forwarding to TagoIO, and a private ChirpStack LNS running alongside Kerlink gateways.
- A TagoIO account (free plan available)
- A Kerlink gateway (iStation, iFemtoCell, Wirnet Station, or compatible)
- A LoRaWAN network server: Kerlink Wanesy Management Center or self-hosted ChirpStack
- Registered end devices on your network server
Architecture overview
Kerlink gateways act as radio packet forwarders. They do not run application logic: that sits on the LNS. The LNS decodes LoRaWAN frames, identifies devices, and routes application payloads to your chosen endpoint.
Your integration point with TagoIO is always the LNS, not the gateway directly.
[LoRaWAN sensors] → [Kerlink gateway] → [LNS (Wanesy or ChirpStack)] → [TagoIO via HTTPS]
Path 1: Kerlink Wanesy Management Center → TagoIO
Wanesy MC supports push notifications (also called “push connectors”) that POST device uplinks to any HTTPS endpoint.
Step 1: Create a device in TagoIO
- Log in to admin.tago.io.
- Go to Devices → Add Device.
- Select HTTPS as the connector type.
- Name the device (e.g.,
kerlink-end-device-01). - Click Create Device and copy the Device Token from the General tab.
Device documentation: docs.tago.io/docs/tagoio/devices
Step 2: Create a Push Connector in Wanesy MC
Log in to your Wanesy Management Center account.
Navigate to Applications and open or create an application.
Go to Push connectors and click Add.
Choose HTTP as the connector type.
Set the URL to:
https://api.tago.io/data -
Add the HTTP header:
Device-Token: YOUR_TAGOIO_DEVICE_TOKEN -
Set the push format to JSON (default).
Save and enable the connector.
Wanesy will now POST every uplink from devices in this application to TagoIO.
Step 3: Parse the Wanesy payload in TagoIO
Wanesy sends a JSON object with device information and the base64-encoded payload. Add a Payload Parser to your TagoIO device to extract the sensor readings.
Open Devices → [your device] → Payload Parser and write:
// Wanesy payload structure
const decodedBytes = Buffer.from(payload.payloadHex, "hex");
// Example for a temperature/humidity sensor with 2-byte temperature, 1-byte humidity
const temperature = decodedBytes.readInt16BE(0) / 100;
const humidity = decodedBytes.readUInt8(2);
payload = [
{ variable: "rssi", value: payload.gwInfo?.[0]?.rssi || null },
{ variable: "snr", value: payload.gwInfo?.[0]?.snr || null }
Adjust the decoding logic to match your sensor’s payload format.
Payload Parser docs: docs.tago.io/docs/tagoio/devices/payload-parser
Path 2: Kerlink gateway + ChirpStack → TagoIO
Many Kerlink operators run ChirpStack alongside their gateways, either on-premise or in the cloud. ChirpStack’s HTTP integration can push data directly to TagoIO.
Step 1: Configure the Kerlink gateway as a packet forwarder
Most Kerlink gateways run the Semtech UDP Packet Forwarder or the Kerlink Common Packet Forwarder. Point the gateway at your ChirpStack Network Server’s address and port (default: UDP 1700).
Access the gateway CLI via SSH or the Kerlink WMC to update global_conf.json with your ChirpStack server address.
Step 2: Register the gateway and device in ChirpStack
- In ChirpStack, go to Gateways → Add gateway and register your Kerlink device.
- Create a Device Profile matching your end device’s LoRaWAN version and region.
- Register your end devices under an Application.
Step 3: Add a TagoIO HTTPS integration in ChirpStack
In your ChirpStack Application, go to Integrations → HTTP.
Set the Uplink URL to:
Add the custom header:
Save.
Step 4: Parse ChirpStack payload in TagoIO
ChirpStack sends uplinks as JSON. If you configure a codec in ChirpStack, the decoded object arrives in payload.object. Otherwise decode the raw bytes from payload.data (base64).
// ChirpStack with codec configured
if (payload.object) {
payload = Object.entries(payload.object).map(([key, val]) => ({
variable: key,
value: val
} else {
// raw decode from base64
const raw = Buffer.from(payload.data, "base64");
// add your sensor-specific decoding here
payload = [];
Step 5: Verify in the Live Inspector
After completing either path, open the Live Inspector on your TagoIO device and confirm data arrives on the next uplink cycle.
Live Inspector docs: docs.tago.io/docs/tagoio/devices/live-inspector
Step 6: Build dashboards and alerts
Create a dashboard from Dashboards → +. Typical widgets for a Kerlink-based smart city or industrial deployment:
- Map widget for device locations
- Time-series charts for sensor readings over time
- Signal quality cards showing RSSI and SNR per gateway
- Heatmap if you have many nodes reporting to a coverage area
Set up Actions for:
- Threshold alerts (temperature, vibration, flood detection)
- Device offline detection (no data received in X minutes)
- Automated reporting via email or webhook to a ticketing system
Actions docs: docs.tago.io/docs/tagoio/actions
Use case examples
Smart city utilities
Kerlink Wirnet iStation gateways mounted on lamp posts. Sensors monitor water pressure, waste bin fill levels, and air quality nodes across a municipality. TagoIO aggregates all readings, shows a city-wide map, and triggers alerts to city operations when bins reach 80% capacity.
Industrial vibration monitoring
Kerlink iFemtoCell gateways in a factory. LoRaWAN vibration sensors on rotating machinery report to TagoIO. Analysis scripts compute FFT-based anomaly scores and flag early-stage bearing wear before failure.
Analysis docs: docs.tago.io/docs/tagoio/analysis
Building energy management
Multiple LoRaWAN energy meters connected through Kerlink gateways to TagoIO. TagoIO stores metering data, computes daily and monthly consumption per circuit, and generates cost reports. Blueprint Dashboards give floor managers their own view.
Taking it further with AI
TagoIO’s MCP server enables natural-language queries over your Kerlink sensor data. Ask Claude: “Which devices have the worst signal quality?” or “Show me all anomalies in the vibration data from the past week.”
MCP docs: docs.tago.io/docs/tagoio/tago-ai/tagoio-mcp-ai-powered-iot-data-integration
Summary
Kerlink gateways forward LoRaWAN packets to a network server. The network server, whether Kerlink’s own Wanesy MC or a self-hosted ChirpStack, pushes device payloads to TagoIO via HTTPS. A Payload Parser in TagoIO decodes the binary data into clean variables for storage and visualization.
- TagoIO Devices: docs.tago.io/docs/tagoio/devices
- Dashboards: docs.tago.io/docs/tagoio/dashboards
- MCP Integration: docs.tago.io/docs/tagoio/tago-ai/tagoio-mcp-ai-powered-iot-data-integration
