The new Custom widget is here!
In late 2019 we removed the ability for new users to register as end-users inside TagoIO (admin.tago.io), and next Monday May 18th, all end-users still registered in TagoIO's admin will be converted to developers. It means that any user accessing admin.tago.io will see the same options presented to developers.
Try out our new Custom Widget that allows you to add your own widget design into your dashboards.
It more than an iFrame inside of your dashboard, you can add parameters and make it communicate with your devices, collect inputs from your end-users, and more. Just as a few ideas, now, you can use Google maps, Google Earth, or create your own map to display devices with geolocation.
The sky’s the limit when using this widget. You can build your widget using Angular, React, Vue.js, or even plain old Javascript.
Example of a custom widget created at TagoIO platform and dashboard
Start creating your own custom widget here.
Share your experience and ideas in our Community.
TagoIO Team.
