Agriculture
Connecting Farm Machinery Beyond Cellular Coverage
Farm machines work where networks end, which kept them disconnected for twenty years. Satellite closed that gap, and the makers of pivots, dryers and pump sets can now bill by the hectare and service by the trend.
Remote monitoring lets a maker of center pivots, grain dryers, pump sets, tractors or milking systems see every machine on every farm, including the ones far beyond cellular coverage, and turn that visibility into recurring revenue: service plans that catch a wearing gearbox before a pivot stalls mid-pass, and irrigation billed by the hectare actually watered. In the example on the Agricultural Machinery solutions page, one pivot bills 503 hectares at $4.80 a hectare, and books its own gearbox service along the way.
Key points
  • Coverage stopped being the blocker: LoRaWAN covers the farmstead, cellular covers machines that move, and satellite (Skylo NB-NTN, or direct-to-orbit services such as Myriota) covers the pivot past the last tower.
  • Output is measured in land, so the top business model is unusually concrete: dollars per hectare irrigated, per season, with every pass guaranteed.
  • Wear announces itself as current draw: a pivot tower motor drawing 25% more at the same pace is a gearbox asking for service weeks early.
  • This is already running in production: BinVision monitors hog and poultry feed bins on TagoIO so farms plan feed purchases instead of climbing bins to guess.
The connectivity decision comes first
On a farm, connectivity is chosen per machine, not per fleet, and all three paths land in the same account:
Three ways a farm machine reaches the cloud: LoRaWAN near the barn, cellular on the road, and satellite via Skylo NB-NTN or Myriota direct-to-orbit beyond coverage, all converging on TagoIO
The solutions page groups the catalog the same way: feeding and milking systems report over Modbus from their controllers; grain dryers and silos over LoRaWAN or Sigfox; tractors, harvesters and sprayers over cellular, MQTT or HTTP; pivots, drip systems and pump sets over satellite where nothing else reaches. TagoIO receives NB-NTN satellite traffic through Skylo over TagoTiP, and direct-to-orbit options like Myriota fit the tiny, infrequent payloads of the remotest points. Installed machines retrofit with add-on sensors for drive current, water pressure, temperature or location, with no change to their controllers.
Which measurements matter on farm machinery?
Measurement What it tells you What it sells
Drive current Gearbox and motor health per tower Service before a stall
Tower alignment and water pressure The pass is actually happening Per-hectare billing, pass guarantees
Soil moisture Irrigation hitting its target Agronomy subscriptions
Grain moisture and temperature Dryer and silo performance Drying billed per tonne, spoilage alerts
Engine hours Duty on tractors and pump sets Maintenance by condition
Milk tank temperature Cold chain compliance Quality guarantees
The walkthrough: a gearbox caught mid-season
The page’s simulated example is worth the numbers. Pivot 14 waters a home block; at the same pace, tower 6 starts drawing 25% more current than its healthy-drive reference, enough to cross its service limit. The signature is a wheel gearbox wearing out, the classic failure that strands a pivot mid-pass in the driest week of the year. A gearbox service joins the next visit, the farm is told, the part is replaced, and current returns to normal. The month closes with 503 hectares irrigated, the pass guarantee kept, and a $2,414.40 invoice.
The fleet view shows the business at scale: 232 hectares watered at $4.80 a hectare so far in the month ($1,113.60, up 8% on October), one pivot of four needing attention, and $3,844.80 ready to bill across the fleet, each line itemized by hectares. Smaller machines ride the same rails: a simulated tank sensor schedules a 3:30 PM milk pickup with 7,680 liters aboard at $65 a month; a grain probe flags a hot spot 9 degrees above the mass at $90 a month.
Proof from the field: BinVision
The solutions page carries a production case rather than a simulation: BinVision, built by Envision in North Carolina, puts level sensors on hog and poultry feed bins and forecasts when each will run out, so farms plan purchases instead of ordering in a rush, and nobody climbs a bin to look inside. James Friedrich, BinVision’s Managing Partner, credits the full-stack platform for making it practical. The full story is in the BinVision use case, and the free Connected Farms ebook covers what growers do with machine and field data once it flows.
The business models, priced
Model What the farm pays for Basis
Monitoring and service plan Pivots that never stall mid-pass $ per machine, monthly
Output billing Land actually worked $ per hectare irrigated, per tonne dried
Fleet benchmarks Water and energy per hectare across farms $ per farm subscription
Season guarantees Every pass completed in the window Premium on the output rate
The progression between the rows, from connected product to outcome contract, is the ladder we laid out in Climbing the Fusion Ladder; in agriculture it is shorter than anywhere else because the output already has a unit everyone bills in: the hectare.
Where does TagoAI fit?
TagoAI assembles the views so your team stays on the machines. Describe the screen you need in the TagoAI panel, for example “a pivot board per farm, quiet while tower currents sit in range, flagging any tower that drifts”, and TagoAI builds the widget and its code against live devices; in the page’s sample it singles out the one tower drawing 1.3 A on Pivot 14. Verify its output against device data before a farm sees it. For the drift detection itself, the trained models in TagoIO Analytics learn each machine’s seasonal normal, so a current that is healthy at the start of the season does not false-alarm at the end of it.
Why the maker, and not the dealer, wins this market
A dealer sees the machines it sold in one territory. You see every machine you ever built, across climates, crops and duty patterns, and that difference compounds into knowledge nobody else can offer: which gearbox lasts in sandy soil, what water per hectare correlates with yield in each region, which failure precursors show up in year three. As we argued in What Makes a Moat in IoT, that fleet record is the defensible part of an equipment business. In agriculture it is also the sales pitch, because the grower buying a pass guarantee is really buying your confidence, and your confidence is only as good as your data.
Frequently asked questions
Can machines already on farms be connected? Yes. Add-on sensors for drive current, water pressure, temperature or location retrofit over LoRaWAN, cellular, satellite or other supported networks. New machines send from the controller over MQTT or HTTP.
Our controller has a proprietary format. Is that a blocker? No. A payload parser converts it into named variables as each message arrives.
Can each farm see only its own machines? Yes. Access Management policies isolate every customer in a TagoRUN portal under your brand, with the Custom Domain & Whitelabel and Custom Mobile App add-ons for your own domain and store listing.
How is per-hectare billing computed? An Analysis totals hectares irrigated, engine hours or grain dried per customer per month and posts the figures to your billing system over HTTP.
Is the platform reliable enough for a season guarantee? TagoIO runs on AWS in the US or the EU with a 99.9% uptime SLA for eligible accounts, ISO 27001 certified and GDPR compliant. Details at tago.io/trust.
Start before planting season
Connect one pivot or one dryer at a friendly customer’s farm and let a season of data price your service plan. The Agricultural Machinery solutions page walks the path end to end, from the retrofit sensor to the invoice per hectare. The machines already stand in the field; the only change is that now they report what the field got.
