How to
How to Connect Robustel Cellular Routers to TagoIO
How to connect Robustel industrial cellular IoT routers (R2000, R3000, R5020) to TagoIO. Covers MQTT and HTTPS forwarding, RobustLink SDK, Modbus-to-cloud bridging, and industrial remote monitoring use cases.
Robustel makes industrial cellular IoT routers and gateways used in remote monitoring, utilities, transportation, and industrial automation. Their R2000, R3000, and R5020 series connect field equipment via RS-232, RS-485, Modbus, and I/O interfaces, and communicate over 4G LTE, 5G, or Wi-Fi.
TagoIO is the application layer: it receives data from Robustel devices, stores it over time, drives dashboards, and triggers alerts. Connecting Robustel to TagoIO gives your field operations a cloud application backend without building a custom server.
This guide covers MQTT-based integration (recommended for real-time data) and HTTPS REST forwarding.
  • A TagoIO account (free plan available)
  • A Robustel gateway (R2000, R3000, R5020, or compatible model)
  • Cellular SIM card with data plan installed in the Robustel device
  • Field instruments connected to the Robustel RS-485 or I/O ports
Architecture overview
[Field instruments] → (RS-485/Modbus or digital I/O) → [Robustel gateway]
                                                               ↓ (MQTT or HTTPS over cellular/LTE)
                                                          [TagoIO]
Path 1: Robustel → MQTT → TagoIO (TagoTiP)
Robustel devices support MQTT natively through their RobustLink application framework and the built-in MQTT client.
Step 1: Create a TagoTiP device in TagoIO
  1. Log in to admin.tago.io.
  2. Click Devices → Add Device.
  3. Search for TagoTiP and select it.
  4. Name the device and set a Serial Number (used in the MQTT topic).
  5. Copy the Authorization Hash from the General tab.
TagoTiP MQTT docs: docs.tago.io/docs/tagotip/transports/mqtt
Step 2: Configure MQTT on the Robustel gateway
Log in to the Robustel web interface and navigate to Services → RobustLink → MQTT:
Setting Value
MQTT Broker Host mqtt.tip.us-e1.tago.io (US) or mqtt.tip.eu-w1.tago.io (EU)
Port 1883
Client ID any unique string
Username First 8 hex characters of the Authorization Hash
Password Last 8 hex characters of the Authorization Hash
Publish Topic $tip/YOUR_SERIAL/push
Step 3: Map field data to TagoTiP payload
Configure the Robustel RobustLink data collection to poll your Modbus registers or digital I/O at the desired interval, and format the publish payload using the TagoTiP syntax:
[temperature:=87.3#C;pressure:=4.32#bar;alarm_input:=0]
For Robustel devices with the RobustLink SDK (supports Python scripting on R5020 and R3000 Pro):
import paho.mqtt.client as mqtt
SERIAL = "robustel-site-01"
AUTH_HASH = "your_auth_hash_here"
HOST = "mqtt.tip.us-e1.tago.io"
# Read Modbus registers (example using pymodbus)
temperature = read_modbus_register(1, 40001)
pressure = read_modbus_register(1, 40002)
client = mqtt.Client()
client.username_pw_set(AUTH_HASH[:8], AUTH_HASH[8:])
client.connect(HOST, 1883)
payload = f"[temperature:={temperature}#C;pressure:={pressure}#bar]"
client.publish(f"$tip/{SERIAL}/push", payload)
client.disconnect()
Path 2: Robustel → HTTPS REST → TagoIO
For simpler deployments or devices without full MQTT configuration, use the Robustel HTTP client to POST data to the TagoIO API.
Step 1: Create an HTTPS device in TagoIO
  1. In TagoIO, go to Devices → Add Device → HTTPS.
  2. Name the device and copy the Device Token.
Step 2: Configure HTTP POST on the Robustel device
In the Robustel web interface, navigate to Services → RobustLink → HTTP:
  • URL: https://api.tago.io/data
  • Method: POST
  • Headers: Device-Token: YOUR_DEVICE_TOKEN, Content-Type: application/json
  • Body template:
  {"variable": "temperature", "value": ${temperature}},
  {"variable": "pressure", "value": ${pressure}},
  {"variable": "signal_strength", "value": ${rssi}}
Robustel’s RobustLink HTTP client supports variable substitution in the payload body using the ${variable_name} syntax for mapped data channels.
Sending data docs: docs.tago.io/docs/tagoio/devices/sending-data
Step 3: Verify in the Live Inspector
Open the Live Inspector in TagoIO and confirm readings arrive on the expected schedule.
Live Inspector docs: docs.tago.io/docs/tagoio/devices/live-inspector
Step 4: Build dashboards and alerts
From Dashboards → +, create an operator dashboard. For Robustel remote monitoring deployments:
  • Map widget showing all remote site locations (use latitude/longitude from GPS-equipped Robustel devices)
  • Time-series charts for key process variables
  • Status cards showing last communication time and cellular signal strength
  • Alert log showing recent threshold events
For multiple sites with identical layouts, use Blueprint Dashboards.
Set up Actions for offline alerts when a Robustel gateway stops reporting (cellular outage or power loss).
Use case examples
Remote pump station monitoring
Robustel R2000 at a water utility pump station. Reads flow, pressure, and level via Modbus from a PLC. Sends to TagoIO every 60 seconds over LTE. TagoIO dashboard shows real-time station status. Alert fires and triggers an SMS if the pump goes offline or pressure drops below minimum.
Pipeline leak detection
Robustel R3000 Pro at multiple points along a gas pipeline. Pressure sensors connected via RS-485. TagoIO Analysis scripts run delta-pressure calculations between adjacent points and flag anomalies consistent with leak signatures.
Analysis docs: docs.tago.io/docs/tagoio/analysis
Fleet and mobile asset tracking
Robustel R5020 in trucks and construction vehicles. GPS + CAN-bus data sent to TagoIO every 30 seconds. TagoIO map widget shows live fleet positions. Idle time and fuel consumption calculated via Analysis and surfaced on an operations dashboard.
Taking it further with AI
TagoIO’s MCP server lets AI assistants query your Robustel field data in natural language. Ask: “Which remote sites lost connectivity in the past 24 hours?” or “Show me average pump pressure for each site over the last week.”
MCP docs: docs.tago.io/docs/tagoio/tago-ai/tagoio-mcp-ai-powered-iot-data-integration
Summary
Robustel cellular routers connect to TagoIO via MQTT (TagoTiP) or HTTPS REST, sending Modbus and I/O data from field instruments over LTE. The integration is configured on the Robustel side through its RobustLink framework, with no additional middleware required.
